Question about Dryers
I want to disable the end of cycle buzzer on a maytag PYE2300AYW model dryer. I have disconnected the barrel end of a black wire directly next to a purple wire. 1. Is this safe? 2. Why does maytag make it difficult to do this?
3 Suggested Answers
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
  • 686 Answers
SOURCE: disable buzzer on Maytag Atlantis MDE6200AYW
it could be done by taking the control panel off and maybe diconnecting the buzzer other than that what I have researched there is no other way sorry
Posted on Feb 18, 2009
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
How can I disable the buzzer on my maytag supersize capacity 7 cycle electric dryer? It is SO loud! Thanks!
Most of these dryers have the buzzer located in the upper console somewhere. If you're handy with a screwdriver you'll have to take some screws out, maybe take the back off and hunt around inside there for a small, round item with two wires going to it. Disconnect one side and try the dryer for the end of a cycle. If the buzzer doesn't go off you're good. If it does, reconnect the wires you removed and look for another item similar to it. Basically that's all there is to it, just finding it is the hard part.
Jul 03, 2011 | Dryers
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    I have a Maytag MDE9206AYW model electric dryer. The buzzer at the end of the cycle is extremely loud. Can the volume be adjusted?
    No unfortunately the buzzer volume cannot be adjusted, the only option is literally disconnecting it inside the wiring compartment where the dials are.Let me know if this helps
    Jan 19, 2011 | Maytag MDE2600 Electric Dryer
    Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
    Either the control board or the humidity sensor is bad.
    Jan 11, 2010 | Dryers
    Maytag Dryer model number PYE2300AYW will not start.
    check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
    Oct 12, 2009 | Maytag Dryers
    Disabling the signal end of cycle on ge dryer
    The buzzer is inside the control switch area. Its about the size of 4 stacked 50 cent coins. Kill the power to the drier and then open the control panel and locate the buzzer. Remove the two wires; using electrical tape, you can tape up each wire end and then secure it out of the way. :?) DRRXR
    Feb 02, 2009 | Dryers
    Two things: I would like to disable the annoying buzzer that sounds which sounds when the drying cycle is over. I want to clean out the slot where the lint filter sits, but am afraid to pull very *******...
    Hello Walky,
    The vent cavity can be cleaned fairly easily without removing it by adding a section of flex tubing to your vacuum cleaner. Most hardware stores sell clear plastic tubing in various sizes so choose one that will fit inside the lint trap area ( normally ~ 1/2" or so and add that to your vac hose with duct tape or equivalent)... If you slash cut the end of it....you can better vacuum the grated surface inside that filter housing.
    The buzzer module can be unhooked from inside the dryer. Try this website for location details
    http://www.pcappliancerepair.com/model-display.php Slide 3 Control Panel shows the wherabouts of the buzzer ( item 11 ) which you should be able to disable by removing or cutting the wire ( please do this with the power disconnected . Also , make sure that you cover any exposed wire ends with an electrical tape, wire nut or some insulator to prevent accidental shorts.
    Hope this helps you..
    Oct 05, 2008 | Maytag Dryers
    Dryer end of cycle buzzer
    disconnect the BUZZER wire from the Timer
    Sep 16, 2008 | Crosley CDG6000 Gas Dryer
    Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
    • the buzzer is located under the control panel.
    • you can unplug it.
    • unplug the dryer or turn the breaker off first
    • then take out the 2 screws on both sides of the control panel
    • bull it forward toward you and unhook it from the case
    • you should see the buzzer with two wires going to it
    • only need to disconnect one.
    •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
    Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
    Dryers Logo
    110 people viewed this question
    Top Dryers Experts
    Marvin
    Marvin
