Question about Whirlpool 21.7 cu. ft. Side-by-Side Refrigerator ED22PQXF
My whirlpool model ED22TE
Fan seems to work but is blowing warm air, not cooling or freezing. Whit can I do to fix the problem?
  • 9 Answers
SOURCE: whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Posted on Jan 28, 2009
  • 3 Answers
SafetyDan, you probably have a bad starter. i replaced mine its working again. if after replacing the starter you still have the problem then it's a bad compressor but the starter can be found locally or online for about $40-$70 depending on where you live. i found it online here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=263269
Posted on Feb 25, 2009
Greg20
  • 149 Answers
SOURCE: Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Posted on Jun 14, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
aasc
  • 1606 Answers
SOURCE: have a whirlpool refigerator. Model ET8BPKXKZOO.
The overload/relay which pluggs onto the side of the compressor is bad . Pt # 2262181
Posted on Aug 07, 2009
Model mtb1950gr. Freezer stopped working. Fan is blowing cool air up there, but everything is completely thawed. Refridgerator part below it seems to be working fine. Vaccumed back.No change.
Your defrost may be stuck on. Cool air is not the same as freezing air. Frost free freezers use less than freezing air passed over and through the food to warm any ice crystals and move the moisture out of the freezere.
Apr 03, 2016 | Maytag Refrigerators
THE FREEZER IS FREEZING,BLOCKING THE VENT TO THE FRIDGE, which is warm Whats happening here.?
U OBVIOUSLY HAVE A CIRCULATION PROBLEM? If the air cannot circulate it remains in the freezer freezing faster and more then usual. you may have the air flow inlet blocked or it has shut closed and refuses to open and close properly. by the way the fan is blowing right cuz a failed fan will also do this?
Dec 04, 2014 | Whirlpool Refrigerators
I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air...
Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
Oct 14, 2013 | Whirlpool ACE244XS Air Conditioner
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
I have a 7 year old Amana bottom freezer fridge model ARB2259CW. The freezer seems like it's freezing just fine, but the fridge is either not blowing any air or blowing very little air. Things in the...
if you can hear a fan blowing in the freezer that is probably not the problem. If it is at all possible could you clear out the fridge overnight. If so, do so, unplug refrigerator with doors open overnight and plug it in in the morning. If it returns to cooling you probably have a defrost problem, but you at least have a couple days to fix it.
Jun 14, 2009 | Refrigerators
Whirlpool ET18TK model evaporator fan
if cover is off there will be no air down there..was there frost on the coils ? if no then compressor is not running..if compressor is running and no frost..no freon or compressor valves shot.
Jun 10, 2009 | Refrigerators
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
My hot point refrigerator will not cool or freeze.is there
let someone check the pressure of you FREON that is one of the problem need to look on
Mar 06, 2009 | Refrigerators
The freezing and refrigerator compartments of my Whirlpool refrigerator began to warm up yesterday, and there is essentially no cooling today. The interior light works, and the fan on the lower par of the...
Greetings fjehlert,
Usually this is indicative of a freon or compressor problem. I would suggest contacting a repair center as soon as possible.
Thanks,
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Refrigerators
Refrigerators Logo
228 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
