Question about Akai LCT1560 Television
My 1080 P is having vertical lines run across the screen so bad that I can't watch it. After a while it will start working again. Any solutions.
  • 11,361 Answers
Yes, it can be the T-CON board (more likely), or the main logic board, or worst case will be the LCD panel.
Try cooling the T-CON board first with small fan or freeze spray for electronics troubleshooting blowing in the T-CON board (the back has to be open) , it is under the metal shield taht must be removed.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find
Posted on Aug 01, 2010
Getting a vertical green line across my laptop screen
SOUNDS LIKE YOUR SCREEN IS CRACKED OR THE LED INSIDE THE SCREEN
Jul 14, 2012 | Computers & Internet
After a while their was a white line that appeared on the screen and now we cant watch TV. We can hear sound and everything but the only thing we can see is a bright white line
Your vertical IC may have bad grounds. Resolder the pins on the vertical IC. You will also need to replace a capacitor or two that are located next or very near the vertical IC. I would guess you are concerned about a horizontal line that runs east to west across the screen. The info just mentioned will fix your problem. Give me a few hands and thanks for asking me!
Sep 03, 2010 | RCA F32650 32" TV
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Rows of Lines across top of screen
I decided not to repair, but use the 16:9 feature on the remote control.
a kind of letterbox look, not bad at all.
I'n not going to spend money, replacing the vertical output ic circuit's bad capacitor or vertical power supply for bad cap.
Jun 11, 2008 | Toshiba 24AF43 24" TV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Akai LCT1560 Television Logo
29 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
