Question about Car Audio & Video
Need wiring diagram for us audio usa603zx 800wat power amp
2 Suggested Answers
SOURCE: jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Posted on Nov 09, 2010
I need a wiring diagram for 05 dodge durango sound and ves systems.
  • 2005 Dodge Durango Car Radio Stereo Audio Wiring Diagram
  1. Car Radio Constant 12v+ Wire: Gray/Red
  2. Car Radio Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
  3. Car Radio Ground Wire: Black
  4. Car Radio Illumination Wire: Black/Yellow
  5. Car Stereo Dimmer Wire: Orange
  6. Car Stereo Antenna Trigger: N/A
  7. Car Stereo Amp Trigger Wire: N/A
  8. Car Stereo Amplifier Location: N/A
  9. Car Audio Front Speakers Size: N/A
  10. Car Audio Front Speakers Location: N/A
  11. Left Front Speaker Positive Wire (+): Dark Green
  12. Left Front Speaker Negative Wire (-): Brown/Red
  13. Right Front Speaker Positive Wire (+): Brown/Yellow
  14. Right Front Speaker Negative Wire (-): Brown/Light Blue
  15. Car Audio Rear Speakers Size: N/A
  16. Car Audio Rear Speakers Location: N/A
  17. Left Rear Speaker Positive Wire (+): White
  18. Left Rear Speaker Negative Wire (-): Dark Blue/Red
  19. Right Rear Speaker Positive Wire (+): Brown/White
  20. Right Rear Speaker Negative Wire (-): Brown/Orange
regards, Tony
May 12, 2011 | Dodge Durango Cars & Trucks
I need a wiring diagram for the jensen lxa400. Pushing 2 kenwood 6x9 (200 watt rms each) and 2 dual voice coil 12's (300 watt rms each) in a truck box. Everything is 4 ohm. Thanks, Curtis
you shouldn't need a diagram all you need is these items here.
purchase a 4gauge wiring kit
run a a power line from battery to amp with a in line fuse 6in from battery.
run a ground from car frame to amp. ( scratch paint and screw it down with an eyelet for good contact)
run a remote from radio to amp.(blue wire)
run rca's from the radio to the amp ( sub input on back of radio)
finally connect your speakers.
Mar 26, 2010 | Jensen LXA400 Car Audio Amplifier
Jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
Mar 15, 2010 | JBL BP1200.1 Car Audio Amplifier
Need wire diagram koiiler xm 7676
U CAN GET ALL UR WIRE DIAGRAMS FROM PIONEER WEBSITE JUST OUT IN UR MODEL NUMBER THEN TYPE IN WIRE DIAGRAM
Feb 13, 2010 | Koiiler XM-7676W Car Audio Amplifier
I need a wiring diagram for installing 2 LT980-2
do you need help just for the power or for the audio or both?
power it is simple
positive goes to the battery but with a fuse in the middle
negative goes to a metal ground point on the car (but not battery)
remote goes to the radio with should have a blue and white cable if radio does not have remote line then use the acc wire from radio
for sound
your amp does two speakers and im guessing you want the back ones amplified
so cut the 4 wires that come from the radio and goes to the back speakers 2 positive and two negative
and connect this to the input the phono terminals on the back (unless your radio has phono terminals for audio out on the back side
then take the output from the amp and run it to the speakers one positive and negative to each speaker
i cant seem to find a wiring diagram for that amplifier but i can give you a more genral diagram
http://www.caraudiohelp.com/how_to_install_a_car_amp/how_to_install_a_car_amp.htm
Jan 05, 2010 | Power Acoustik LT-980/2 Car Audio...
I NEED FREE DIAGRAM OF CAR STEREO AND AMPLIFIER
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Jun 14, 2009 | Alpine CDM-7854
Wiring diagram
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Aug 07, 2008 | Pioneer DEH-P2000 CD Player
Wiring diagram and manual needed for wd810
The manual can be found here: http://www.rmeco.net/images/IB/durabrand/WD810.pdf Also, here are some standard wire colors: Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Sep 02, 2007 | Durabrand WD810
Car Audio & Video Logo
94 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
