Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
I need to find an exhaust manifold for my Rinnai energysaver 1001FT
    Novelist:
  • 120 Answers
I'm sure you have looked but the best bet is to go through Rinnai and find local parts dealers or installers who can get you the parts.
Always willing to help, let me know the area you are in country etc.and I will see if i can recommend anyone.
I have contacts in Oz and NZ.
I can also send a link for the parts if that helps or just look up the model you should find a pdf..
Exhaust fluing for these units is tricky to specify as there are lots of different parts available depending on how you want to run the pipe. Recommend getting someone in who has good experience installing these as this will save alot of time (and money). We used to get so many installers trying to return parts that were incorrectly ordered.
Posted on Aug 01, 2010
My rinnai energysaver 1001ft will not turn on.It has power to it but it will not power up when switched on.no lights no go.HELP;;
Hello Mark Obrien,
I searched the internet trying to get a HIT from your
rinnai+energysaver+1001ft
and all combinations there-of...
I also went on-line to a MAJOR RETAILER site & poured over their inventory of systems and parts (see below)...
Alpine Home Air Products Contractor grade furnaces heaters air...
Nothing... so:
Assuming you are talking about a heater here
If you are seeing no "lights"...
perhaps checking the SECONDARY side of your
POWER TRANSFORMER would be the best advice...
If that has the required (typically 24 volt output)
continue on to your main control board...
(looking for the Typical FUSE (usually 5 AMP)...
If the fuse is OPERATED... replace it...
f it operates again... IT is time to consider purchasing that
SPARE MAINBOARD you always wanted...
Like a YORK furnace... (verify your OWN NUMBERS)
031 01267 001A OEM Upgraded York Furnace Control Circuit Board by BDP... (PC (Main Control Board)
ALSO CHECK HERE
https://www.supply.com/rinnai-furnaces/b2098
Fuse kit
Amazon com Bussmann NO 44 ATC Blade Fuse Tester Puller Kit Home Improvement
Hope this helps...
Carnac the Magnificent
Jun 25, 2017 | Rinnai Heating & Cooling
I have a rinnai 1001ft heater but i need the flue is there enyone that has one please
You should be able to get the flue kit from any Rinnai resellers.
There are many different flueing options existing for Rinnai Energysaver depending on where you wish to install it (by a licensed gas fitter only of course).
Depending on what flue kit you need for your own situation you could be looking anywhere between $150 to $800 (AUD).
Go on their website for a list of resellers.
Mar 19, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
We have a RINNAI ENERGYSAVER 1001FT, if power or gas has been turned off, it takes several attempts to restart it.
If the gas was tunred OFF, yes it would take several attempts for the pilot to light. Because, there is air in the line from the gas line shutoff valve to the heater. Once that's purged, the heater should light. The electrical power shouldn't affect it. Unless, the heater hasn't been serviced in the last year. Unfortunately, they are not maintenance free.
Jul 06, 2011 | Heating & Cooling
How to install
Unfortunately, the installation of one of these units is not quite as simple as 1, 2, 3.
So, I am providing a couple links on the installation process. You can download and print each one.
The first is the Flue Installation Guide.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/CI_ES_Flue_Inst_Manual.pdf
The second is the Operation Guide, which also deals with proper installation.
The third is the exploded parts view & parts diagram, Which you may need in the future.
I hope all of this information will help you properly install the unit.
Jun 02, 2011 | Rinnai EnergySaver 556 Air Conditioner
Have inherited a Rinnai energysaver 1001 FT gas heater - need an exhaust manifold
Found a link to the service manual for starters
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/225.pdf
The flue system looks very similar to some current models. I'd go to Rinnai direct and try and get a list of local service agents who can order the bits in. The flues are very tricky to order because there are so many different bits depending on where you need it to run so order carefully.
Jul 30, 2010 | Rinnai Heating & Cooling
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
Rinnai energysaver 1001ft won't turn on. Was okay when last switched off. Cleaned filters and green light comes on for a short time but no red light to ignite starter for gas. After less than 1minute...
Wet your finger first- then plug the item in, the filters should run in reverse. Make sure that the filter is in right. This was made in China and it is read left to right not right to left. The translation got it backwards. Fix this and the flow will make all well.
Sep 27, 2009 | Heating & Cooling
Rinnai Energysaver 1001FT, ignites, blows 5mins then shuts down.
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
Jul 07, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
122 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
