Question about Panasonic CT-27SX11 27" TV
Trying to Fix Tilt
Today I decided to fix the tilted picture on my Panasonic CT-27SX11 TV. I took the back off, adjusted the yoke so that the picture would be straight. Then I had difficulty getting the case back together. Finally I did and proceeded to turn the set on. The picture was extremely dark and I could not see the setup menu, because all the boxes were black, No text was present or I could not see it, If could get into the menu or reset the set somehow, I'd be in business. Unless I disturbed something when I took it apart. Help!! Please help!!
    Problem Solver:
  • 16 Answers
I think your TV has develop a many loose soldered parts on it.physically it was on the Brightness circuit portion.one way to restore it is to resolder all loose part on cicuit board...
Posted on Apr 25, 2008
What is cost of yoke for panasonic ct tv?
You're discussing about the width problem to picture. If yoke have a short in between its wingdings [even a single winding short], will cause the failure of horizontal output transistor. As per you report here, the set has a raster, but problem is with the picture width.
There possibliliites for this fault are.
1. Lack of voltage from the SMPS power supply output.
2. Horizontal width capacitor.
3. Horizontal output capacitor.
Check the output voltage from the SMPS section first, and confirm that it is OK.
Jan 03, 2013 | Panasonic CT-24SL13 24" TV
TV
the slugs have nothing to do with tilt; unless a tilt setting in main menu bonded yoke has no adjustments for this issue.
Mar 07, 2012 | Televison & Video
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Picture is slightly tilted
Its an easy adjustment but it requires you to work around the deflection yoke on the neck of the picture tube. Above the yoke is a red connector that is carrying 30,000 volts then on the yoke itself you have wires that are connected to the horizontal and vertical circuits that can carry up to a 1200 volt pulse. So this alignment is not for anyone but a technician. I personally would leave the tilt until you can have a technician touch it up for you. Take a moment to rate my answer. Thanks...
Nov 20, 2009 | JVC AV-32FA54 32" TV
Fixing Tilt
YOU PROBABLY TOUCH THE SCREEN VOLTAGE ADJUSTMENT LOCATED ON THE FLYBACK TRANSFORMER. BECAREFUL ADJUSTING IT LPUS IT IS HIGH VOLTAGE USE A PLASTIC ADJUSTMENT DRIVE.
THANKS DOCTOR VIDEO
Apr 24, 2008 | Panasonic CT-27SX11 27" TV
Top half of picture blanked off. Bottom half does not indicate any deflection problems.
the problem is in your deflection coil, the other half had been shorted probably.
Mar 19, 2008 | Panasonic CT-27SX11 27" TV
Picture on tv
check for a bad solder at the the tuner section or within the tuner . Bad solder ground within the tuner can cause this fault
Apr 21, 2007 | Panasonic CT-36D32 36" TV
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Panasonic CT-27SX11 27" TV Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
