Question about Fisher and Paykel Washing Machines
Washer stops and beeps with lights flashing some times inside of blow looks like it has dropped about 25mm and cloths are getting dirty marks on them
    President:
  • 1,554 Answers
It sounds like the tub is not floating to disengage the drum from the spin hub or the agitator is restricted, especially when the last 4 lights and the third from right light of the Wash Progress lights flash to indicate fault code 47. The flashing lights indicate the fault code and determines exactly what the issue is. Please specify which among the lights are flashing for accurate and appropriate troubleshooting advice.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 01, 2010
My washing machine makes marks on everything
LG WM2101HW 4.0 cu.ft. Washer Stains clothes ruining ...
www.fixya.com > ... > LG > LG WM2101HW 4.0 cu.ft. Washer
... stains out with anything and they are ruining numerous items of clothing. ... stainson light objects ie making white marks on light blue clothes ruining these ... by greasestains from their front loader Kenmore. .... remove the agitator from a ...
Oct 19, 2015 | LG WM2101HW Front Load Washer, White, 4.0...
Ken more washer leaves dirty marks on clothes
Pull the agitator out and clean the inside of it and the area of the tub that it covers. A buildup of crud won't be removed by simply washing out the machine. Rinsing out a frying pan will get a lot of the dirt out but, it must be properly washed to get it all.
Jan 20, 2013 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Our GE front load washer model #GBVH5200J2WW quits in the middle of the cycle, any ideas why?
Check and see if you get any code when your lights are flashing when it stops ?Alot of the times your screen inside of the hose stops up Turn off the water going to the washer and take off your hoses and look at the screens if they are dirty replace them .If it stops and your clothes are still verrrry wet then you have sucked something inside of the pnmp .Take off the bottom cover and you will see a grey rubber thing that hooks to the bottom of the tub then it hooks to the pump take a good pair of channel locks or agood pair of pliers and take the little hose off the pump and you sould see something in there like a baby sock a small washcloth or anything if you find that then you are set .Good Luck
Oct 15, 2011 | GE Washing Machines
Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
We are using model #gwl15 fisher and paykel top load washer. When it gets to the rinse cycle it justs beeps. It won't go any further. It is not unbalanced. I've taken all of the clothes out of the...
Hi just read your posting.Now when it beeps and stops do any lights flash or come on?If they do they will be on a row of 8 lights.Starting from the far left which lights are on or flashing?Are they the 1st and 4th light or 3rd and 6th --etc--?Please look underneath the machine and look to the front right of the machine You should see your pump which should have a red or black fan on it.Turn this fan a few times and hopefully this will loosen your pump if it is jammed.If you have the pump without the fan please reply and I can guide you throe unjamming it.I think with your symptoms you have described, you might have a jammed pump.Please reply for further help.Hope this helps.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Grease, or some substance on clean clothes
You need to thouroughly clean the large door seal in all of its grooves and the inside of the door as well. Just put on gloves and use detergent to do this and rags or pape rtowels. Also make sure the inside of the tub is clean and that you are not overfilling the washer. Good luck.
Aug 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
