Question about Sanyo Televison & Video
Changing country selection for lcd tvs
Changing country selection for lcd 37xr9da tv - reset itself by itself, even though the manual says australia is the default country. is there a combination of buttons on remote control that can do the job and reset to australia again?
Mine has just done the same thing. I'd be interested in an answer as well.
Posted on Aug 19, 2010
We bought a veon tv in NZ and now have moved to Australia. The tvs country is still NZ. How do I change it to Australia.
get the on screen menu up and look for the area transmission format
Australia is PAL
Sep 22, 2016 | Cell Phones
How do I change country code on Vivid AldiTV
stop by a TV shop and ask them most of your Stuff down under is different than these up state side
Aug 30, 2015 | Televison & Video
Onida 32" LCD TV
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 14, 2017 | Televison & Video
Out of box factory reset
Refer its user manual for details.
Jan 29, 2013 | Sanyo DP42849 42 in. HDTV
Manual for sanyo 37 X R9DA
Sanyo Australia support site has the manual for the 37XR9DA LCD TV: http://www.sanyo.com.au/support . The direct link to the manual is http://www.sanyo.com.au/resources/manuals/tvs/lcd37xr9da_im.pdf .
I hope this helps.
(note: you will need Adobe Reader or a similar program to read or print the manual)
Jan 10, 2012 | Televison & Video
My toshiba 40RV525u flat TV is muted, the tv seems like it controls itself when i go to Menu (selection flashing nonstop). I tried to turn up the volume, but it turned off itself. the entire problem is the...
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 27, 2017 | Toshiba 40RV525U 40 in. LCD TV
'satellite' icon not available to retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
South american tv not working in australia. can i
110v is used in the mains in the US,what about Australia?Is it 110 or 240v? Also you need to check the frequency and if it is suitable for Australia..Say secam,pay etc..
Sep 05, 2009 | LG 22LG30 22 in. LCD HDTV
42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Nov 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
263 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
