Question about Weber Genesis Silver B Grill
I get a humming sound when after last knob is turn on, the first 2 knobs, there's no sound. Sounds like the humming is coming from the regulator area. Soapy solutionb indicates no leak.
  • 140 Answers
That is normal with propane grills do not worried about it
Posted on Aug 06, 2010
Compressor runs and sounds ok, but it only manages to show 20 lbs. It will not build air pressure and continues to run.
check air tank drain valve located on bottom of tank, if it is not leaking try adjusting air pres regulator (large black knob close to air hose connection.) the knob when turned in will increase the tank air pressure, if knob wont turn check that lock ring on bottom of knob to make sure it is disengaged. also check for air leaks in all lines and connections
Apr 16, 2012 | Craftsman 1 hp Air Compressor, 4 gal. -...
Worked fine previously. Now when turned on the tank pressure comes up normally . However, the regulated pressure gauge reads zero and there is no airflow.
What happens when you twist the regulated pressure knob, as you would to increase the regulated pressure? Does the knob turn? Does it turn until it stops, but still reads zero? If so, it sounds like the regulator pressure spring is broken. That's inside the regulator, and you will probably have to replace the regulator.
Jun 16, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Our weber grill is suddenly getting too hot... even with only 1 of the 3 burners turned on it is over 400 degrees... any ideas?
Sounds like the regulator is not controlling the flow of gas. Try this. 1. Turn gas tank and burner control knobs off. 2. Turn tank valve on VERY slow. 3. Open front burner knob on and lite grill. Wait a minute and turn on addition burners, (if needed).
Apr 27, 2010 | Weber Genesis Silver A Grill
HUM NOISE OCCURES WHEN TURNING KNOB TO LEFT BEFORE PUSHING KNOB TO START- STOPS WHEN POINTING TO OFF POSITION - MODEL GYC4000AWW . DRUM DOES NOT TURN
it sounds like you have a bad motor and door switch. the unit should not run unless you push a start button. the humming noise is the motor. either something is blocking it or your motor is bad,
Oct 12, 2009 | Magic Chef CYG2000AWW Gas Dryer
My whirlpool top load washer will not start when I pull the knob. It makes a humming noise.
Motor sounds like its not starting up strong
May need a motor....
Jun 02, 2009 | Washing Machines
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Humming noise
1st. Are the humming evident when the flame ain't burning? Listen carefully. The control(knob) consists of a valve that regulate the supply of gas to the burner. Check each knob(valve) individually for noise. If noise is evident on the knob(valve) contact your dealer for service or replacement of valve.
2nd. Check the gas regulator. That will be the unit that is exiting the gas bottle. Noise might be evident from the regulator due to the gas being controlled. If excessive noise is evident. Service or replacement of the unit might be necessary.
Aug 07, 2008 | Weber Genesis Silver B Grill
Individual burner knobs not functioning
This is a problem with the regulator. Sounds to me like the pressure coming from the regulator is too high. You can get these regulators at most major hardware stores or directly from the manufacturer.
Hope this helps
Jun 18, 2008 | Uniflame FG2204C Grill
It won't start
Sounds like the motor start winding or motor relay is bad.. or something caught in you exhast blower. See if you can turn the drum with your hand.. if so you can try, helping it take off while having someone turn the start knob if it starts you know its the motor
Aug 19, 2007 | Frigidaire GLER642A Electric Dryer
Weber Genesis Silver B Grill Logo
134 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
