Question about Breadman TR2200C Ultimate Bread Maker
Paddle drive shaft in bottom of pan has seized up. Is shaft and seal available or do I have to purchase a whole new pan? Thanks
  • 433 Answers
Hi, Unfortunately the sealed bearing and shaft can not be replaced. Hank
Posted on Aug 02, 2010
When i put in the baking pan, the kneading blade does not move
If the motor is working and the paddle doesn't move, take the pan out and see if the drive shaft is turning. If not then it's probably a broken belt. If it is then check for a seized shaft in the pan.
Mar 29, 2015 | Sunbeam 5891 Bread Maker
The device on the bottom of the bread pan appears to be locked and will not turn to knead the dough. Is there anything I can do? It worked fine the last time I used it.
The synthetic seal around the shaft which DRIVES the paddle is fried.
I need a replacement to fit on the shaft OR if necessary 2 new shafts with NEW seals
Feb 28, 2011 | Breadman TR2200C Ultimate Bread Maker
Hi, I had all my ingredients in the pan and was bringing it to the machine to begin making bread. When I noticed the liquid was leaking out from the bottom. I had a mess everywhere. Come to find out the...
Hi, The leaking is from the sealed bearing that the paddle shaft rotates on. It wears out over time. It can not be repaired and you will need a new bread pan. Sorry Hank
Nov 23, 2010 | Breadman TR2200C Ultimate Bread Maker
I have the Black and Decker All-In-One Deluxe Automatic Breadmaker B1600 Series and it's worked well for years. Today I put the ingredients for a loaf in the bread pan and when it started to mix the paddle...
There is a sealed bearing in the bottom of the bread pan. The paddle sits on the sealed bearing shaft. Over time the bearing begins to fail and the paddle does not turn freely or it may even freeze up. If you are sure everything is installed correctly this may be the problem. See if the paddle moves freely by hand and is not really loose. Sealed bearings can not be replaced. Eventually you will need a new bread pan. Sorry Hank
Apr 21, 2010 | Black & Decker Bread Machine
The container that bakes the bread has a tab on the bottom that turns, and is on a shaft that goes thru the bottom, and this shaft is held by a snap-ring. we can't get the tab off,(supposed to come off to...
Thank you for visiting Fixya. The tab you speak of is called the paddle. The paddle sits on a shaft that is pressed into a sealed bearing. This shaft is not supposed to move in the bearing. If the shaft moves the bearing will lose it's seal and lubricating fluid (oil) will leak out. The snap ring, bearing, and shaft are put together before they are installed into the pan. If you can't fit the ring back onto the shaft so the shaft doesn't move, then you should hunt around for a new bread pan. P.S. Putting soapy warm water in the pan and letting it sit for a while will free up the paddle so it lifts off the shaft. Also lubricating the shaft with a squirt of olive oil will help stop the paddle from sticking on the shaft. Good Luck...Hank
Nov 28, 2009 | Zojirushi Kitchen Appliances - Others
Hi, I love my Black&Decker bread maker, but recently it has black swirl stuff on the bottom of the bread. I found it was from the center mixer. The mixer is getting loose and it can be moved up and...
Hi Jenny,
The black swirl stuff is the lubrication from the bearing that used to be sealed on the bottom center of the bread pan. (The paddle fits onto this bearing shaft). That bearing is broken and is leaking, causing the whole bearing and shaft to move. Time for a new bread pan.
Hank
Oct 27, 2009 | Kitchen Appliances - Others
The driveshaft falls out of the pan, even with paddle attached
The shaft is pressed into a bearing that is molded and stamped in the bottom of the pan. This bearing is sealed and allows the shaft and paddle to spin freely. The rest of the parts on the other end of the shaft interact with the motor on your machine. They do wear out and can not be repaired because the worn parts are not available individually.
Sorry to say there are no repairable parts, so it's time for a new bread pan. I don't know the brand of your machine so you can google or check ebay.
Hank
Sep 02, 2009 | West Bend 41052 Bread & Dough Maker
Breadman TR2200C Ultimate Bread Maker Logo
544 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
