Question about Ford Garden
I have a 2000 New Holland 28 tractor.......after about 30 min of bush hogging it loses power and runs strong then drops 1000 rpm and goes back up and runs for a while and back down...At times it will bogg down and stop running completely
  • 51 Answers
Check air filter andfuel filter. sounds like its starving for either one under load
Posted on Aug 01, 2010
Yanmar 4BY2 with 1000 hours overheats when run above 2000 rpm - this is new, she cruises at 3500 rpm all day when running OK. Loses 1 gal water in 5 min at 3200 rpm. No visible leaks, smoke.
I would jump in the water and spin the prop by hand make sure there's no excess drag and your cutlass bearings ok.
if thats all good I would suspect your F/W pump, your losing water gotta look good at the weep hole when running. Wipe the pump, clean the bilge, run the boat, you will see the leak.
Aloha
May 17, 2018 | Boating
Ford 2000 tractor stalled bush hogging (Too slow near the fence line, no engine prob). PTO was engaged, was in 2nd/high. Cant get it out of gear to restart.Cant lift the bush hog up--cant do anything.
Have someone help you rock the tractor back and forth and see if it lets go ,if not jack up rear wheels and rock them back and forth.
Aug 31, 2016 | Ford Garden
New Holland tractor
Sensor, wiring or computer failure.
Jun 26, 2016 | Cars & Trucks
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
Pto on our 165 massey furguson will not turn fast enough to run bush hog can anyone trouble shoot?
Hi Lynn:
The speed of the PTO on every tractor I've owned has been directly related to engine RPM and there has been no other way to change it.
Did your bush hog work with it at one time? If it did, what has changed since then? That might give an indication of a possible fix. It may be that the tractor and bush hog are not compatible.
May 14, 2015 | Garden
'99 silverado 5.3 engin will not idle runs at 2500 rpm and drops down to 1000 rpm the back up to 2500 rpm -------------------------
which car is it?
problem with 1993 Geo Prizm '99 silverado 5.3 engin will not idle runs at 2500 rpm and drops down to 1000 rpm the back up to 2500 rpm -------------------------
Apr 15, 2013 | 1993 Geo Prizm
Bush hog zt2200 that keeps throwing belts
outdoor power equipment.com website will show you the diagram you must type in your model and brand? most of the time the pulleys get bent and out of alignment then the belt twists off once that happens it impossible to reuse old belt ? just make sure it lines up and the tensioner is working?
Aug 27, 2009 | Garden
Eclipse won't idle .
Throttle body, IAC or EGR valve.
Mar 12, 2017 | 2003 Mitsubishi Eclipse Coupe
Oil pressure
At operating temp 171 - 181 F, with SAE 10w-30: idle @ 700 rpm 11 psi min, 1200 rpm 28 psi, 2000 rpm 43 psi, and 4000 rpm 57 psi.
Dec 16, 2008 | 1987 Nissan Maxima
Garden Logo
202 people viewed this question
Top Ford Garden Experts
fordexpert
lnbn1975
Matt Olenzek
Matt Olenzek
Are you a Ford Garden Expert? Answer questions, earn points and help others
