Question about McCulloch Garden
How to adjust carby settings after rebuilding. McCulloch Eager Be
How to adjust carby settings after rebuilding McCulloch Eager ****** 2.0 chain saw( old model).
    Brigadier General:
  • 4,088 Answers
Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that should allow the engine to start and run. Start the engine and allow to warm up, then pull throttle full on. Adjust H needle CW until the engine starts to speed up, but continues to 4-stroke. Proper setting is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Posted on Aug 02, 2010
Where to find the model number on the eager beaver chain saw
You'll need to contact your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
May 08, 2013 | McCulloch Eager Beaver 2.1 Parts List
McCullough Eager Beaver model#40010205 392 chain saw manual/parts
Contact us
User manuals
McCulloch Service
Nov 19, 2012 | McCulloch 14" Electric Chain Saw Mcc1514
Exploded parts view of mculloch 2014 eager beaver
Refer to your service manual.
Contact us
User manuals
McCulloch Service
Nov 07, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I trying to find a bar & chain for a Mcculloch eager ****** saw. Only model numbers I find are 60012416or 12-052701. Saw had 16" bar which has broken.Was using Oragon S54 chain.
Here is a good website for finding bar and chains from the Oregon website.After you get the part # you want you can always purchase from other source.
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Hope this helps.
Feb 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mcculloch eager ****** 2318av what fuel mix does it use
chain saws are 40:1
3.2 ounces 2-cycle oil per gallon gasoline
Oct 25, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain saw
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel line for decay or other damage. Make sure you have fresh fuel mix in the tank (40:1) using a modern synthetic oil made for saws. If the above doesn't help, you will need to remove the carburetor, clean it inside and out with spray carburetor cleaner and check the lower chamber diaphragm for flexibility--no holes or cracks. If the two jet needles have been disturbed, turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting which should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on and adjust the H needle CW until the engine starts to speed up, but 4-strokes. Correct adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
May 21, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How do you adjust the automatic oiler on a eager ****** 3.7 chain saw.
I cannot find an Eager Beâver with 3.7 CID (60.6cc). Provide a model number and we can dance, without it I cannot answer your question. Reply below please. Is it a Timber Bear?
Mar 11, 2010 | McCulloch Garden
Where do I find a replacement chain for my McCulloch Eager ****** 2318av chain saw (model # 600038-12)?
Your friendly neighborhood chainsaw shop can fabricate one in about 5 minutes. Take your existing chain for use as pattern.
McCulloch.com
http://www.ordertree.com/modelinfo/MCC/11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318/139.11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318.1.59.1.html
If original 18" bar.
part number(pn) MCC 21927533
Oregon Bar & Chain Selector (again original 18" bar)
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your saw with 18" bar returns
Oregon pn 91VG060G.
This can be easily crossed to other manufacturers chain. You might consider a more aggressive chain (dependent on your level of expertise). HTH
Lou
Jan 20, 2010 | McCulloch Garden
Garden Logo
311 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
