Question about Miele CVA615 Espresso Machine
No 'real' coffee taste or crema - despite following instructions
I have a Miele CVA 620 and have tried all settings but the coffee always tastes watery. I've tried different coffee beans have read the manual inside out and still not avail... please someone help
Set the machine for the finest coffee and the least water.
You should get a decent espresso.
For a regular cuppa, keep the settings the same and make either a medium coffee combined with a small coffee (jolt) or
make two small coffees.
I have this machine and the crema is nice at this setting.
Posted on Oct 03, 2010
  • MarkBok Aug 08, 2011
    I thought my machine was broken - it was part of the home we bought a few years ago and could only make flavourless brown water. The only remedy was doing the above and buying "italiansk brent" (Norwegian for "Italian burned" - not sure of better translation) was the only remedy. Very strong coffee beans, fine grounds and lots of, with little water. Very nice coffee now!
  • cbnhr Aug 09, 2011
    Glad I could help! I'm making a cup right now! Cheers!
Miele CVA4070 Coffee not hot enough
Here is what I would do;
1. Determine if you have noticed a change. i.e was the coffee hotter in the past or has it always been this temperature. If the cups are cold or the amount of water used for each cup is small then the resulting coffee will be cooler than if warm cups were used or if the amount of water used was larger. Also if the water is not hot enough you will not get a good Crema and coffee taste will not be correct.
2. Assuming the problem is not '1' above then the likely causes is the flow through water heater. This heater is used to heat water for coffee and also for the hot water. So if the hot water pipe is also not producing hot water then you know it's a problem with the flow through water heater or power control of this module. In addition to the actual heater there is a temperature limiter, temperature fuse and a temperature sensor. If some heating occurs then it is not the temperature fuse. But it could be a fault in the actual heater, the sensor or the limiter. These components are at mains voltage and thus identification of the fault and replacement of defective parts should ONLY be performed by a trained Miele technician. So if this is the problem its best to call Miele.
I hope this helps. Regards
Mar 10, 2014 | Miele CVA4070 Coffee Maker
Bitter taste
You will likely find the bitterness is a function of your coffee bean choice or the 'roast' component of that coffee. Darker roasts tend to taste bitter.
Nov 03, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
Miele CVA 620 part 9161.391.xx0 where does it go ? Can I obtain instructions for setting up a new grinder ?
miele-cva-620-part-9161-391-xx0-go-nsr413nfwic5kgfniqnnhys0-3-1.jpgIt is the cover of ground coffee quantity. You loose it when you unscewed the first scew of coffee bean container base.
Jan 22, 2013 | Coffee Makers & Espresso Machines
BITTER TASTING COFFEE
I would check the temperature of water. Sounds like it might be too hot. The temp of the water should be between 192 and 197. Colder and its sour, and hotter and its bitter.
Mar 13, 2010 | Rancilio Coffee Makers & Espresso Machines
My brand new Bunn BX... despite following exact measuring for the perfect cup of coffee, and trying various stronger measurements, my coffee comes out tasting like water. When I look at the grounds after...
It sounds like you might be missing your sprayhead. If you remove the filter basket and look up above it, there should be a dome piece with 5 holes in it. If not, please call customer service with the model and date code and we can provide you with a new sprayhead.
Dec 25, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Jul 05, 2009 | Miele Coffee Makers & Espresso Machines
No program mode in Miele CVA620 espresso machine
my miele cva 620 coffee machine not working only the LED screen lit up and nothing else? any ideas.
Apr 10, 2009 | Miele CVA2650 Stainless Steel Espresso...
No cream on the espresso when dispensed
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Nov 05, 2008 | Gaggia Tebe Espresso Machine
Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jul 16, 2008 | Gaggia Titanium Espresso Machine
Miele CVA615 Espresso Machine Logo
887 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
