Question about Maytag MTB2156GES Top Freezer Refrigerator
Fridge runs intermittently
Runs well for 12-36 hours then fails. Everything in freezer melts. Bottom goes tepid. Quickly revives by turning it off and back on again. Problem began during July heatwave in NYC. Kitchen was HOT. Machine is about a year old. Thanks Adam
  • 7,365 Answers
You have a defrost timer or defrost element that went bad, only a service tech can tell which one, because they both have to be checked & they are checked differently
Posted on Aug 01, 2010
  • Maytag Master
  • 1,606 Answers
The thermostat has a mercury separation . Replace the thermostat ( the piece that the knob pushes on to ) . Pt # 61002043 . Costs about $50.00 and is easily replaceable . Just be sure to unplug the refrig before replaceing .
Water keeps pooling up on the bottom of my fridge and freezing
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | General Refrigerators
Fridge icing up
If your machine is a side by side
If your machine is a top mount meaning that the freezer is on top
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
May 17, 2012 | Fisher and Paykel Refrigerators
We came home from a weekend away and the freezer was slightly ajar. Everything had defrosted. Additionally, the refrigerator was warm. We closed the freezer and turned the temperature control to the...
There is a good chance that your refrigerator has frozen up from the door being left open.
The best and easiest thing to do is to unplug the refrigerator and prop the doors open for 24 hours to melt any ice build-up that may have occurred and then restart the refrigerator.
If the refrigerator still fails to pull down to proper temp, then you will need to dig deeper to find the problem.
Jun 07, 2010 | GE Profile PDS20SFSLSS Stainless Steel...
Leaking inside
The drain in the back of your freezer is frozen. When the defrost cycle runs, the water has no where to go except through the panel into your refrigerator.
Turn the refrigerator off. Take everything out of the freezer and store it someplace for a few hours. You can either let the freezer thaw on its own or help it out a bit. If you want to speed the process, remove the rear and bottom panels from the inside of the freezer to expose the coils and the bottom pan. Stay away from the coils. Melt/chip away all of the ice in the pan. With a hair dryer, melt the ice in the back of the pan. Soon you will see the drain - concentrate on melting the ice in it. Some hot water and a sponge can help speed the drain clearing process. When the water drains freely, finish drying out the rest of the freezer and reassemble the rear and bottom panels. Turn the refrigerator back on, and you are good to go.
Jan 30, 2010 | Kenmore Refrigerators
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Sep 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 31, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
I have a 4 year old Kenmore top freezer refrigerator. the defrost function is malfunctioning. the freezer frosts up, clogs the air vents, the fan runs nonstop, and everything melts. I've turned off the...
Should be covered alright. Sounds like the defrost therostat is open. Is you defrost heater coming on. It doesn't seam like it is. As you frig runs it's cycle it will turn off the compressor every hour or so and the timer will turn on the heater in your freezer to defrost. Do you feel this heater coming on. If you therostate mounted on the defrost ellement fails to close then your heater will not come on and ice will build up in you freezer. These thermostates seam to be failing more and more these days. I've replaced mine 3 times over the last few years.
Jul 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Jan 25, 2008 | Refrigerators
Maytag MTB2156GES Top Freezer Refrigerator Logo
241 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
