Question about Grundfos MQ3-45 1 HP Pressure Booster Pump
Grundfos pump leaking?
We have a grundfos MQ that pumps water to a cabin via an above ground cistern.
Lately it will turn on about every 15 seconds and run for a about 5 seconds regardless of demand.
It sounds as though there is air leaking inside the pump. From the crappy manual provided with the pump I thought it would be the check valve so I tried to get to it....
I have removed the pressure tank and I am assuming the check valve is directly behind it but I have no idea how to remove it. Am I at the right area and if so how do I remove it? Or can someone suggest another solution.
Thanks.
  • 760 Answers
If it is starting and stopping, it most likely does have some type of leak. The check vavlve is normally installed on the suction side of the pump, and sometimes instead of a check vavlve or in addition to, there is a foot valve. A foot valve is just a check valve (usually with a screen) at the end of the line in the bottom of the cistern. If you have much suction lift, and the check valve leaks (or any leak in the suction piping) then the water will drop back into the cistern. This will also cause the discharge side of the pump system to drop in pressure, causing the pump to restart. You mentioned removeing the pressure tank, that tank keeps the pump from short cycling when you have low demand on the system. If the pump is higher than the cistern, and you don't see a check valve between cistern and pump then you most likely have a foot vavle in the cistern. Hopefully it's accessable by removing the pipe.
Posted on Aug 01, 2010
I have a submersible deep well pump and lately if I run the water for 15 minutes straight it shuts off why.
Grundfos pumps are thermally protected by a bi-metal strip temperature switch. Your pump is overheating. Typical cause of this is operating to near the shutoff head pressure. Try reducing the discharge pressure by increasing the flow rate.
Jun 25, 2016 | Grundfos Pumps Grundfos 60S50-9 61530095...
Grundfos pump
Louise, since there is several different types and models of Grundfos pumps it would be hard to answer your question. To possible point you in the right direction below are a few links to where you can find some PDF documentation about a popular Grundfos pump the MQ series and direct link to the manufactures "Service Support".
Service support
Grundfos MQ Series Pumps
Feb 07, 2014 | Garden
Grundfos MQ 35 won't run
Sounds like the discharge is plugged. You can get the manual at: http://rainwatercollection.com/download/Grundfos-Manual.pdf
Jan 24, 2014 | Plumbing
Triton t200re shower
Paul. Is it only the shower that the pump cuts out? i dont think we have these pumps in AU. Would bet that its a flow issue. Either remove the water saving device in the shower, if there is one. Pr turn another tap on just a dribble when you start the shower?
We have these issues with "smart"? controllers that think there is a leak
May 19, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Grundfos MQ pump starts every 15 seconds
Pressure is bleeding back through the pump or system to the tank or well or where ever the water is coming from. Should be some sort of one way valve to keep water from going back to the source, mounted somewhere so that once pressure is pumped up, it will hold that pressure in the part of the system that has the pressure switch that controls the pump.
That or you have a leak where you can't see it. (Actually you do, it is just internal and not leaking outside the pipes!)
Nov 04, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Low pressure from grundfos pump to house
Does your system equipped with pressure tank (pneumatic tank)? If it has, maybe it's already filled with water due to some pinhole leaks. Drain the tank and see what will happen.
Oct 30, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
I have a problem with mq booster pump every 10 seconds kicks back and kicks on i am check the showers no leaks everything is ok please tell what can be a problem
Grundfos said the problem of on off every few seconds was air in the line. Then
later admitted it was the control unit. After replacing two units in 2 yrs I replaced
it with a standerd pump pressure switch.....Runs fine
Nov 17, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Hi, I have a Grunfos mq cold water booster pump. It is cutting in and out when the water is not in use, Turns on for 15 seconds tehn off for a minute. I have checked for obvious above ground leaks which...
First check with a pressure gauge to see that the pressure is, indeed, dropping. Then, if it is possible, turn off the outlet valve to isolate the pump.
If pressure is still dropping, there is probably a check valve on the inlet of the pump that prevents water from the high pressure side from leaking back to the inlet piping side.
To test this, let the pump run and pressurize the house and immediately close the valve for the incoming water. If the pressure holds, then open the inlet valve and see if the pressure drops. If it drops, the inlet check valve has to be replaced (or cleaned).
Gary
Feb 19, 2011 | Grundfos Plumbing
With the water running the MQ pump runs intermittently
This is a problem with your bladder in the pressure tank or the pressure switch. Ether one will produce this cycling on and off. Good luck.
Mar 09, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
1,684 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Jay Finke
Jay Finke
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
