Question about Whirlpool Duet GHW9150P Front Load Washer
We are getting a sound that the pump is running but no water in entering the drum and we are getting a FH signal readout. we have followed the troubleshooting booklet. Is it possible the pump is bad?
    President:
  • 1,382 Answers
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Posted on Aug 01, 2010
I have the code FH going off on my washer I have replaced the water flow meter the entire inner drum and the outer front half of the plastic drum what else can this be it runs fine until it gets to...
Have you checked the Drain Pump Filter? It is located inside the front lower cover and opens counter clockwise. Have plenty of towels on hand when you open it.
Mar 02, 2015 | Kenmore HE4t 3.8 Cu. Ft. King Size...
FH SIGNAL MEANS ......... WHAT IS THE USE OF FH SIGNAL........ AND APPLICATIONS
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Hi Expert, I have the 9200 Whilpool Duet washer that is now stuck in the rinse cycle and is 1/2 full of water. I tried to drain it by lowering the hose into a pail but no luck. I get the FH code. I have...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have Duet front load washing machine and over the last 7-8 years have battled he FH code.I have opened the machine numerous times, tried to flush and back flush the water valves/solenoids gone back and...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting FH code. Have cleaned inlets and checked hoses. Water is coming in,sounds right but then goes to FH again.
Hi
Daniel
Aug 06, 2011 | KitchenAid KHWS01PMT Front Load Washer
FH is showing on my front load whirlpool washer. I have pressed 2x pause/cancel...will not cancel, pump continues to run.
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. You can check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Apr 13, 2011 | Washing Machines
My washingmachine started to beep and FH showed up on the screen. What does FH stand for?
Hi
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Feb 16, 2011 | Whirlpool Washing Machines
I get a fh every time and have followed instrutions that my customer has recieved
The FH indicates that No water detected entering machine or Pressure switch trip not detected.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
ACTION
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FH flashing on Whirlpool washer
hi....If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it....
thank u!!! rate me!!
Feb 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FH error
You are correct..
FH is an indication the the machine is not sensing enough water flowing into the machine....
The only thing you can do without taking the machine apart is to disconnect the water hoses to the back of your machine and inspect the filter screens for any type of debris that might be restricting water flow into the machine. Typically, the cold water line is more susceptible to foreign matter than the hot waterline.
If screens appear OK then the problem may be with the water fill valve, water flow sensor, (flowmeter) water pressure switch or blockage in the water pressure switch hose.
However.. if everything is fine using just cold, verify hot water for proper pressure or possible kinks in the hose.
Jun 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
