Screen cuts out for 3 seconds then restarts - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
Check all electrical connections from PSU that attach to your hard drive including IDE,SATA and electric extensions make sure your PSU is not faulty
Posted on Aug 01, 2010
My Hp pavilion wont cut on but the screen is blank but the cursor is working
Try a restart first, you may have to hold down the power button for 15 seconds then power it back up OR unplug and pull the battery. On the restart does anything show up on the screen?
Mar 18, 2015 | HP Computers & Internet
Peugeot 407 problems faults
run the fault codes to find the sensor that is generating the problem. I suspect that it may be in the canister system or a faulty venting/purge valve that is affecting the venting for the tank.
Sep 04, 2014 | Cars & Trucks
Starts, 3 secs, turns off, restarts 3 secs repeats
Try removing the battery and restart. Could be a bad memory module, fan not working, CPU going bad, graphics chip overheated and going bad. I assume it is out of warranty so you might have to take it to a repair shop.
Feb 13, 2014 | Acer Computers & Internet
Playstation 3 has power but nuthing coming on tv
depends on wether your connecting ps3 to standard which is rca jack connecters or hd,,hdmi,,if it has been connected hd before and ur connecting standard ,,thats why,,either way,,connect however you want turn on power,,hold power button down for a few seconds,,you may hear a beep,,,if not it may turn off ,,either way should have screen when it comes back on,,if still nothing,,turn it on,,hold power down till cuts off ,,turn on again hold power,,u will here a beep,,keep holdind,,next,,it will be ,,2 beeps reliese,,right then,,a screen will pop up,,,connect usb to controller and restart ,,good to go,,good luck
Feb 09, 2013 | Sony Playstation 3 (PS3) Console
Prs 300 has a frozen screen will not turn off or reset or connect to computer
please look clearly there will be a reset button to restart if there is no reset button then open it with the help of secrew and cut the connection of battery and after few second reconnect the bettery to to turn on but remember the connection should be same as before the cutting mean to and - to - terminals
Sep 09, 2011 | Sony Reader Pocket PRS-300
I was working on facebook last night when my screen faded out then at the top of the screen everything started turning an aqua color with minute sized squares similiar to snow and it took over the screen. ...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
May 18, 2010 | HP Pavilion dv9000z Notebook
Verticle stripes on monitor--Toshiba Qosmio G25-AV513 PC Notebook
Following factors could be causing this problem and solution as well:
1) Cable Cut: check is to see if the cable between the screen and laptop is pinched or cut. Every laptop has this wire that runs through one of the hinges
2) If this problem temporary i mean for some seconds then it could be a short signal cut problem to screen which causes screen distortion
3) Connect an external monitor and restart the laptop. If you see the same strip on the external video, then that is the motherboard or the video card problem in case you have a video card on your laptop apart from integrated graphics chip
Nov 18, 2009 | Toshiba Qosmio G25-AV513 Notebook
My Dell Latritude C610 has a screen issue, there are vertical bars about two inches wide, in several spots on the screen where the colour is different, sometimes red and sometimes blue, but the screen is...
Nov 18, 2009 | Dell Latitude C610 Notebook
Wont cut on
I left it alone overnight and when i went to charge it da next morning, it waz workin fine.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
Computers & Internet Logo
Alun Cox
David Payne
David Payne
