Question about Frigidaire ATF6000ES Front Load Washer
Timer button moves thru cylce but it dont wash spin out the clothes it goes thru clcye in 5 min.
  • 7,365 Answers
Sounds like the timer has gone bad
Posted on Aug 01, 2010
Kenmore washer model 110 82781800 won't cylce, just hear timer ticking
If the motor is going thru cycles and the agitator doesn't move, than it means the drive link snapped. cheap repair. it was made to protect the motor and trans. Read the manual before doing this. it will show you how to do it easily. iv'e done mine around 4 times. my wife keeps jamming too many clothes into the thing.
good luck
Apr 10, 2014 | Kenmore Washing Machines
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
Dont remove all water in spin cycle
clogged drain pump,line or pump is failing.
Feb 26, 2010 | Whirlpool Washing Machines
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Frigidaire gltf2940es3 dont go into spin
put in door lock /switch fixed problem the switch sets behind the rubber seal a thin wire clamp around the seal with a spring at the bottom frount holds the seal in place realy is no problem to change
Apr 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Washer is not washing the clothes properly. Skipping cylcles
If it's new - check if it's under warranty. Let them solve it. Save you money. You've already paid for it once.
Mar 21, 2009 | Whirlpool Washing Machines
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire ATF6000ES Front Load Washer Logo
81 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
