Question about Maytag Neptune MAH9700 Front Load Washer
My mah9700aww door stays locked and when i try to start it in any cycke i just hear a humming coming from the assy pump drain.
Posted on Sep 06, 2010
  • tgsinvest May 27, 2011
    What is the Solution??
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
WHAT SHOULD I LOOK AT FIRST
You need to look at the door lock actuators, I'm guessing 1 is operating but staying on when locked and draining the battery. Try manually locking the doors and see what happens. It may come down to removing the door trims and disconnecting each lock in turn, don't forget the boot lock, until you find the culprit. Its possible you may hear the lock solenoid humming or buzzing or feels warm as its trying to lock the door unsuccessfully.
May 20, 2014 | BMW Z3 Cars & Trucks
Problem with Hotpoint Washing Machines Samsung
ND -not draining. There could be something is stuck in the drain pump or one of the hoses connected to it( normally a coin is stuck in the L-shapped plastic connector to the drain hose)if the system is clear,then I would replace the drain pump.
Nov 02, 2013 | Samsung Washing Machines
The machine had an F in the display window and now I can not open the door - it's locked!
Most probably what is happening is that your washer isn't draining out the water so yhe door stays locked.
Easiest thing to do is open up your bottom panel by taking three screws off
then you tilt washer on a 45degree angle and have a couple of towels close by
unscrew cap on front of drain pompe and you will probably find some foreign objects or if not probably drain pump defective.
But before doing all this put washer in a drain spin cycle and if you hear a weird humming sound its a good indicatio that you will be performing what i suggested above
Jun 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
When I push the button to start the washer, all I hear is a low humming sound...nothing else happens.
since i dont have your model number it makes it tough to be sure. but you have one of three issues happening. if its a front loading washer the the door lock my not be engaging. if you cant open the door then you are probably ok on that.
2. The drain pump is either clogged or the drain pump has failed.
3. check to be sure water is on, you may be hearing the water inlet valve on the machine as it is trying to work. change your water temperature setting and see if that will help.
Levi Holiday
Lebarchrigen Appliance Repair
www.lartoday.com
Dec 09, 2009 | GE Washing Machines
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Mah9700AWW maytag washer dooer is locked
unsrew the lid to soap dispenser and search for the cord , you probably have a bad wax motor(lock motor)
May 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
268 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
