Question about Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System
No water at ic maker - Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System
  • Kenmore Master
  • 7,365 Answers
You have a seal that went bad
or a kinked or bent water line
Posted on Aug 01, 2010
I need help troubleshooting an ice maker
Practical Ice Maker Troubleshooting Tips
www.achrnews.com/.../106192-practical-ice-maker-troubleshooting-tips
Since you're already online, why not visit the ice machine manufacturer's Website and... indicator lights mean with regard to what part of the operational cycle the machine is in, .... that it's the right size and turns in the right direction, and make sure no other appliances .... What does the ice pattern on the evaporator look like?
How To Fix A Refrigerator Ice Maker That Is Not Making Ice ...
removeandreplace.com/2013/.../check-refrigerator-ice-maker-making-ic...
Nov 3, 2013 - Fixing the ice maker on your fridge is not usually a difficult task. ...
Dec 16, 2015 | Refrigerators
No water to the ice maker .I took out the cover of ice maker turn by hand the wheel after one cycle .I heard the sound and water filling up ice maker but when it become ice for long time .the ic
Hi friend, thanks for your post!
I understand that your icemaker on your Frigidaire refrigerator is not getting water to the icemaker. It sounds like you could have an issue within the valve or solenoid. I would recommend having a professional come out to properly diagnose your appliance and repair it. -Matt
Sep 17, 2014 | Frigidaire Refrigerators
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
Have water at door, no ice, changed dual water valve, same problem. What next?
check and make sure that the main fill tube to your ice maker is not blocked with frozen water. If the fill tube is clear then replace the ic maker unit itself
Jun 10, 2010 | Frigidaire Refrigerators
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
The ice maker stopped working .There is water in the plastic tube in the back of the refridgerator but it only gets to about 3/4 of the way up the tube. The water dispencer stopped working years ago but...
Pour about 1/2 cup of water into ic emaker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure the fridge coils are clean and free of dust , lint , pet hair , etc..
VE6GAR 73 88 99...thumbs up..
Aug 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side won't make ice door water works
sometimes as simple as frozen line, check little rubber line at ice maker feed. if ok you may need new controller or ic maker ez to replace either, goto repairclinic.com for info. i would buy new icemaker locally at homedepot round 27 bcks if you need 1
Jun 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
1) Doesn't turn on. 2) Can't remove base plate to diagnose.
I had the same problem.
There are 4 rubber "feet" that conceal additional phillips screws. These feet are easily removed by lightly pulling them out of the screw holes with needle nose pliers.
On my coffee maker, the problem was heat sensitivity with an IC marked "53A3P 512AAC". I was not able to find this IC. If I HEAT this part, the coffee maker will briefly work until the IC cools down.
I would be interested in either finding the board, or IC.
Hope this helps.
-Joe
May 25, 2009 | Cuisinart DCC-450 Coffee Maker
Ice Maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ghhjd
Jan 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker drips water
In most of theses cases the dripping is caused by the molding in the ice maker cracking and the water is wicked out. On some ice makers you can replace the complete molding but its usually easier to just replace the ice maker.
Nov 02, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
