Question about Kenmore Washing Machines
Kenmore washer top load not cycling
Kenmore washer top load stock #20642 fills with water and washes, button moves to next cylce, but won't move after that. It will not rinse or spin.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
You can also go to the following Sears site and click on "Manuals", enter the stock number, select "residential Washers" and click on the actual model number.
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
See the following for how to access the console and Lid Switch connection.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6f8112b458c05fcc8f6d1a4139b9a723
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
It also has a troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires that you release the console and pull the cabinet.
Posted on Aug 01, 2010
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore series 90 washer keeps filling with water and won't stop during to move on to next cycle
If overfills onto the floor , then the waterlevel switch hose came off the switch behind the control panel . You have to remove the 2 side screws and tilt panel to see the hose and switch . If the water keeps filling , but doesn't go on the floor , then you have a syphon problem at your drain . As it fills , water is being sucked out by your drain due to no air able to get in around the drainhose and drainpipe . Pull drain hose out of drain and only insert about 4-5 inches into drain . If hose is tightly in drain , a parts house or home depot should have a syphon break in stock .
Jul 22, 2009 | Kenmore 22422 Top Load Washer
Will not move to the next cycle.
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 07, 2009 | Kenmore 24032\24036 Top Load Washer
    Washer fills but won t advance to the next setting for all cycle
    Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
    Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Kenmore washing machine
    you need to replace the timer it is faulty let me know how you make out
    Oct 30, 2006 | Kenmore 15944 Top Load Washer
    Washine Machine
    -Sounds like the timer is out. Check it out and replace it
    Good luck
    Mai
    May 16, 2017 | Kenmore 22642 Top Load Washer
    Washing Machines Logo
    81 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
