Question about Danby DDR586R Dehumidifier
Help the unit runs but the water goes all over the floor
  • 5 more comments
  • nsomniak6 Apr 29, 2008
    We re having the same problem. It seems to be trying to come out of the unit right before it gets to the tank. It seems like the tank is improperly positioned, but we have tried all different ways to put in , rig it, but to no avail. We are very frustrated because we REALLY need on in our basement and this is the second unit we have to get. The first unit was under warranty, but we are 1 year past the warranty. I called customer service who told me to try things that would have nothing to do with the problem and then said I would have to have a service call which would cost more than the unit.
  • Anonymous May 31, 2008
    We're having the same problem with the unit running but water going all over the floor. The hopper is definitely correctly placed. I'm wondering if there is something blocking the flow of water into the hopper. I can't figure out how to get inside to check that.
  • gscholze Jun 07, 2008
    I get water in the botttom of the unit "inside" and then it leaks onto the floor. This only happends when the unit goes into defrost mode. I do not know why it goes into defrost mode when the temp in 72 to 75 degrees. Currently I am using a hose from the condensate discharge into a bucket. Also I notice that when the unit goes into defrost mode the front coil and air coming out gets cool and the front coil begins to condensate and the rear coil stops condensating. I've read about a discharge tank " which I don't have" I picked the unit up at a garage sale. The unit really grabs a lot of moisture out of the air and seems to work fine except when it goes into defrost mode and leaks water.
  • Anonymous Jun 23, 2008
    same thing, water just runs on floor. everything is positioned corectly...
    and that last help tip for this problem was a waste of everones time....
  • Anonymous Jul 01, 2008
    Water comes out of a small hole on the upper left side that you can see when the bucket is not in place. The water is supposed to come out of the right side into the bucket. The bucket is in place correctly. The result is water running behind the bucket and onto the floor. I have opened it up but can't seem to see why it is going through this tiny hole
  • basementmama Jul 14, 2008
    Motor runs fine, and the green light is not on, but all the water goes onto the floor. The bucket is in properly and there are no holes in it. I have tried cleaning the filter and the coils in the back. Does anyone have a solution? Thank you.
  • marilynewood Nov 07, 2008
    The Danby DDR586R runs but it has dumped water all over the floor and ruined my rug. How do I fix this? Just pulling the plug at the back and draining it doesn't help.
There is a small tube on the left side where the water comes out. Push a q-tip up there and wiggle it around. When I did it some glop came out and it works again. I have to do this about once a month.
Posted on Jul 18, 2008
Raise the unit by placing it on a stble platform
Posted on Jun 23, 2008
The fan is not turning how do I fix it?
Posted on May 26, 2008
Better buy another one. Make sure it is not a whirlpool. Pile of junk.
Posted on May 23, 2008
We are also having the same problem. The tank/hopper is definitely positioned correctly, and the water is leaking all over the floor. It may well be that the water is spilling out somewhere else before it gets to the hopper. Any suggestions if that is the problem?
Posted on May 03, 2008
    Scholar:
  • 150 Answers
Check the water hopper is it in all the way? unit should shut off when it is full or not properly installed. might have a crack in the hopper or water is spilling out somewhere else before it gets to the hopper
Posted on Apr 24, 2008
Flooded floor
yes I agree that you should not have layed it down , please wait for 48 hrs now to run it again with unit in upright position
next id go over unit and look all all hose's seems a bit of mold builds up inside of these very often , Wight id always say to give it a little spritz of bleach water every 30-60 days or so to clean it out and keep your pipes flowing freely
one of those little bottles of compressed air for computer cleaning goes 4 miles to cleaning out little holes and such on these things
Jul 26, 2015 | Danby Dehumidifiers
I have a gold star hd30 dehumidifier. When it was draining into the bucket it was running properly. Recently I installed a hose at the back by inserting the plastic piece provided onto a black tube inside...
Quite possibly, Sara the hose drain tubing was not seated firmly. or the tubing running to the hose connection is partially clogged . When this happens water is diverted to the bucket.
To solve the clogging issue do the following:
Turn the unit OFF & Unplug it.
Remove the the tubing adapter and using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection hole & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the the tubing adapter and tubing, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the drain tubing for water flow and leakage. It may take 10 minutes to start flowing, so be patient.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you to solve the problem and thanks for choosing FixYa.
Sep 13, 2011 | Goldstar DH3010B Dehumidifier
I have a Royal Sovereign BHD 450 dehumidifier. I moved and I do not know how to install the hose into the unit. It looks like it goes into a place in the bottom of the unit. The online manuals I found do...
Yes, there should be a screw out plug for the drain hole on the lower left. If the plug is not in there, the you will have water all over the floor. Unless, you can find the drain cap for it. The auto drain hose connection is about 6" above the manual drain hole, I just mentioned. That is where the auto drain hose connect. It's held in place by a squeeze clamp, that goes on the hose before making the connection. But, keep in mind, with out the drain hole screw in plug, water will still spill onto the floor.
If you can't find it, try Appliance Factory Parts 1-800-955-7075. As they may can help you.
Hope this helped you and thanks for choosing FixYa
Aug 10, 2011 | Royal Sovereign BDH450 Dehumidifier
I have a De Longhi 8C70 Dehunidifyer. It is approximately seven years old. The pump is broken, when I flip the pump switch to the on position, the water no longer goes through the tube but drips into the...
Think the problem is with a clogged tube running to the drain, rather than a faulty pump.
To test this theory, first turn the unit OFF & unplug it. Using an 18" long, appropriately sized, plastic Zip Tie. Carefully insert it into the drain hole tubing and continue to push it in unitil you reach a bend in the tubing. Gingerly work it past this bend until the Zip Tie bottoms out or your run out of usable Zip Tie. Then slowly pull it back out while rotating (twisting) it. This will help break up any clogs. As you reach the tip of the Zip Tie, be prepared as some water may follow. Plug the unit back in and turn the unit ON. Set the control to Pump Mode and monitor the drain for water flow.
I hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | DeLonghi DN40G Dehumidifier
Hi, I have a Haier HD306 Dehumidifier. I'm having an issue of the water dripping onto the floor. There is no crack or leak coming from the bucket itself. The leak seems to be coming from the back...
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
Jul 26, 2011 | Haier HD306 Dehumidifier
No water goes into storage tank
If by "no water goes into the storage tank", you mean it does not appear to be removing any humidity. Then you will need to do the following as, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 22
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have manually controlled
model, set the control knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem.
Jul 11, 2011 | Dehumidifiers
Unit no longer removes water/humidity from air. The filter had been extremly clogged up (now clean) but is fan suppossed to move when it's running ? If so - is it electric or belt driven ? Is...
Well, we know the filter was playing a role in it.. Good job on cleaning that. Depending on where you have the humidity extraction level set, the fan could run all the time (It's direct drive. No belt). I suspect if you lower the humidity extraction level to 35%, you will see/hear water collecting in the bucket after about 30 minutes to an hour of operation.
Also, maintain at least 18" of clear air space around the entire unit.
In addition, if you're using this in a basement Ambient air temperature at floor level is between 40 - 60 degrees. dehumidifiers do not work well between those temperatures Unless, you have a Low Temp Unit). This applies mainly to where the air temperature at floor level is colder than at shoulder level
in basement applications . Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
Hope this helped you to further troubleshoot and solve the problem. Please let me know.
Jul 11, 2011 | Kenmore 54501 Dehumidifier
Doesn't collect water in bucket but runs all the
There are 5 basic things that can cause this problem. All are solvable.
1. The humidity extraction level is set to high. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, remove and clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
5. Ambient air temperature at floor level is between 40 - 60 degrees F. Dehumidifiers do not work
well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to
basement applications, where the air temperature at floor level is colder than at shoulder level.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 18, 2011 | Whirlpool AD25BBK Dehumidifier
Dehumidifier leaking onto floor.
You should clean off the condensor coils with a vaccum and soft brush. Also, check up inside the area where the condensate drips into the collection reservoir (or goes directly into a hose attachment discharge) to see if something is partially obstructing the water flow and is dripping onto the floor, etc.
You might find that you've got some buildup of dust, dirt, and some other gunk that is mis-directing the water (condesate) that the dehumidifier is drawing out of the air.
Lastly, check the unit to see if it's level, but frankly, I highly doubt that's the issue, based on the 5+ years of good working service for you.
So long as the unit is still running and keeping the humidity in check, (if the above steps don't resolve the issue), I'd continue using it until it finally quits running, but I'd put a plastic boot/shoe mat under it to catch the small puddles of water.
The dehumidifier should draw the small puddles, so it'd be less expensive to get a $4 boot mat than dropping another $240+ for a new unit, as your's seems to be working fine, aside from the occaissional puddle issue.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Dehumidifiers
Goldstar dehumidifier
Two possibilities:
1. Continuous running and there is water coming out of the unit to the floor drain; the unit is just doing its job. It is probably just that there is that much humidity in the room;
2. the sensors are faulty or were bypassed during the repair - the sensor would be testing the water coming out, if there is water, the unit continues to work, if none, then it shuts off. Most would also have an overfill float switch, again which could be bypassed, that likewise control whether the unit will continue to run or stop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 03, 2008 | Goldstar DH504EL Dehumidifier
Danby DDR586R Dehumidifier Logo
389 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
Colin Stickland
Colin Stickland
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
