Question about Black & Decker QS800 2.0 Amp 1/4 Sheet Finishing Sander with Convexgrip
Should I do some sort of cleaning maintenance? I've been doing a lot of sanding lately.
    Problem Solver:
  • 14 Answers
Either vacuum or blow up the sander with compressed air
Posted on Aug 01, 2010
Using fusion sterling paint after few day got lots of tiny bubbles. Done tv unitand vedside unit she and after few days bubbles. Any ideas.
Did you do anything to prep the furniture before you painted it? Bubbles usually form because there was something on the painted surface that is giving off gas of some sort, possibly through some chemical reaction to something in the paint. Did you use a chemical to clean it or maybe didn't clean the painted surface before you painted it? It is possible that if you used a cleaner and didn't get the cleaner off the furniture before you painted it this is causing the bubbling. Either that or there was something on the surface that you didn't clean off before you painted it. The only way to get the bubbles out is to sand them out. Use a power sander with a fine sand paper and make sure you wipe the surface down with a wet cloth and let it dry before you paint it again.
Jul 19, 2017 | Games
WD-52725 Picture Quality Problem
sounds like a possible issue with the Optical light engine itself.
Nov 28, 2012 | Mitsubishi WD-52725 52". Rear Projection...
Valve Problem?#2 cylinder has 75 psi, #s 1, 3 and 4 have 175 psi compression.
The carbon is not for lack of maintenance. Its caused by bad gas, additives, and oil. As far as $2000. that's about rite for a valve job. To test yourself to make sure its a bad valve do these few steps.
1. Remove spark plug at #2 cylinder
2. Add a few drops of engine oil into the cylinder
3. Now check the compression.
This is called wet compression test. If the compression goes up, the valves are not the issue. If the compression goes up, you have a bad compression ring on that piston. If it is the valves the compression will not increase. As a last resort before you pay a lot of money, get a can of SeaFoam and follow the instruction exact. This stuff works wonders.
Oct 19, 2012 | 2004 Honda S2000
Engine runs rough
It could be a lot of things. What maintenance has it had? Spark plugs, wires, cap, rotor, distributor, coil, mass air sensor, clogged PCV valve, vacuum leak, primary oxygen sensor, skipped timing, clogged air filter, bad tank of gas, bad battery ground - any of these could cause that. Has the car had any of this done lately? Has it had any other work done lately? Sometimes while doing one maintenance procedure, something can get bumped or disconnected and cause other issues.
Aug 05, 2011 | 1992 Mercury Topaz
Having a problem with the mocospace website, I've been logging lately and the website has been booting me off constantly, I've just had my company check my internet and they said its working fine,...
Try clearing your cookies and cache, this usually helps that sort of problem. The easiest way to do this is by downloading and installing CCleaner here and pressing the "clean" button. Close your browser(s) before cleaning.
Jul 25, 2011 | mocospace.com
My screen is always white, and rarely does it work, I've had two samsung propels do this now, and I did get sand in both of them but not wet sand? what can i do to fix this?
If you are certain that sand has gone into the phone then the phone must be opened and the boards taken out and cleaned using a jet air spray. Brush out all the sand using a tooth brush , check and see if there is corosion if this was sea sand. If so use spirit to clean.
Also dry the board before you set it in and hope it works failing the board can be a suspect.
Jul 21, 2011 | Samsung Propel A767 Cell Phone
Not properly cleaning. I found very fine white sand caked in the upper spray arm. I also had the same fine sand in my kitchen and bathroon faucets. They had filters that were 50% cloged. Does my dishwasher...
The only filters are a screen which will not filter the sand out...
I would consider installing a "whole house" filter that would catch that as it comes into your house.
Unfortunately it is too late for your dishwasher which will be hard to clean the sand out of...
heatman101
Apr 19, 2011 | GE Dishwashers
Top rack not coming clean, glasss especially a problem like a grit sand when done lots of rinse agent at all times
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Maytag 24 in. MDB4651A Built-in Dishwasher
I've changed the ink cartridge in my epsom printer but it wont print, what can i do
If you haven't printed a lot lately, your print head might clogged. Here's what you can do: go to "print", then "properties", then "maintenance", and find the option "head cleaning". You will hear strange sounds coming from inside your printer, nothing to worry about, the printer is just trying to push the ink through the print head. In the end, the printer will print 4 colors: black, yellow, magenta and cyan. If the colors seem ok to you, you have fixed your problem. If not, repeat the process several times (just bear in mind that cleaning the head uses a lot of ink).
Hope that helps, and if it doesn't, please let me know, would love to help find a solution to your problem!
Mar 05, 2010 | Epson Stylus CX5400 All-In-One InkJet...
I just purchased a Canon EOS Digital Rebel XSI 450 D camera. The company I purchased it from is trying to talk me into a maintenance agreement. Among other things it includes a once per year free...
If you drop your camera in the dirt a lot, I would send it in for the cleaning. It just takes one grain of sand, if left to bounce around long enough inside your camera, to enter the lens assembly and jam a gear in the lens gearbox forever. Most sand will not jar loose again, and will require a repair to remove it. If you shake your camera and can hear dirt bouncing around inside, I would take the free cleaning service right away.
Nov 13, 2008 | Canon Cameras
Black & Decker QS800 2.0 Amp 1/4 Sheet Finishing Sander with Convexgrip Logo
42 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
callhow
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
