I ordered a new fan motor kit for Model #600315.321 the instructions are not clear on how to install the electrical, the kit came with a new capacator but no information about removing the old capacator if i add the new capacator there will be 3 capactors on the unit? do you have a wire diagram for this problem
    Novelist:
  • 117 Answers
The new capacitor is to take place of the old one feeding the motor. Other than that, it should be a simple in and out procedure. white, black, and red wires are typically hot legs and the brown wires are for the capacitor.
Posted on Aug 01, 2010
2000 Eldorado blower not working
INFORMATION
Subject:
Revised HVAC Blower Motor Installation Procedures
Models:
1994-1997 Cadillac Seville
1994-1999 Cadillac DeVille
1994-2002 Cadillac Eldorado
The intent of this bulletin is to provide technicians information regarding the proper installation of the Heating, Ventilation and Air Conditioning (HVAC) Module blower motor (with impeller) assembly.
The current available HVAC Module blower motor for the above listed vehicles can be identified by the three mounting holes (1). The original equipment blower motor had five mounting holes.
In order to avoid confusion and ensure a high level of customer satisfaction, when replacing an HVAC Module blower motor, refer to this bulletin for the appropriate procedure.
Eldorado/Seville-HVAC Blower Motor
Caution: Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Removal Procedure
1. Disconnect the negative battery cable.
2. Remove the camshaft cover.
3. Remove the blower motor.
^ Disconnect connector from the blower motor.
^ Remove the blower motor screws (either 3 or 5 screws).
^ Remove the blower motor from the HVAC Module.
1. If present, remove the 2 ribs located on the barrier. Refer to Step 3 and the illustrations in the Instruction Sheet, P/N 52494110, found in the blower motor kit.
Important: Ensure the blower motor gasket makes a complete seal around the blower motor.
2. Install the new blower motor with heat shield. Refer to Steps 4 and 5 in the Instruction Sheet, P/N 52494110, found in the blower motor kit.
3. Install the blower motor retaining screws.
Tighten
Tighten the screws to 4 N.m (35 lb in).
4. Tighten the lower heat shield retaining screws to 4 N.m (35 lb in).
5. Connect the connector to the blower motor.
6. Install the camshaft cover.
7. Connect the negative battery cable.
Oct 09, 2012 | 2000 Cadillac Eldorado
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
How to remove and install a new heater blower motor 2000 Saturn
Removal & Installation
  1. Select the following settings:
    Turn the ignition ON Select Recirc in the OFF setting Turn the ignition OFF
  2. Disconnect the negative battery cable.
  3. Remove the wiper arm assemblies.
    CAUTION A sharp edge is revealed once the weatherstrip is removed.
  4. Remove the weatherstrip at rear of the engine compartment.
  5. Remove the cowl retaining nuts.
    Fig. Remove the cowl screen assembly
  6. Remove the cowl screen assembly.
  7. Rotate the locking tabs outward to release the filter assembly.
  8. Remove the filter by lifting straight up.
    Fig. Remove the wiper module retaining bolts
  9. Remove the wiper module retaining bolts.
  10. Reposition the wiper module to the right.
  11. Remove the filter housing attachment bolts.
  12. Remove the filter housing.
  13. Remove the blower motor housing:
  14. Remove the blower motor housing screws
    Fig. Release the locking tabs and remove the fan housing
  15. Release the locking tabs and remove the fan housing
  16. Disconnect the blower motor electrical connector.
  17. Squeeze the bottom of the connector and pull downward.
  18. Remove the blower motor assembly by lifting straight out.
To install:
NOTE The fan motor assembly rib must be located into the channel in the module housing.
  1. Install the blower motor assembly into the module housing.
  2. Connect the blower motor electrical connector.
    NOTE The housing rib must fit into the slot in the HVAC module case.
  3. Install the blower motor housing. Snap the left and right clip into place
  4. Tighten the fan housing to blower motor housing screws to 9 inch lbs.(1 Nm).
    NOTE A new filter housing seal must be used whenever the filter housing is removed to prevent water from leaking into module.
  5. Remove the filter housing seal using a small flat-blade screwdriver.
  6. Install a new filter housing seal.
  7. Install the filter housing.
  8. Install the filter housing screws, and tighten the screws to 31 inch lbs.(3.5 Nm).
  9. Position the wiper module.
  10. Install the wiper module bolts, and tighten the bolts to 44 inch lbs.(5 Nm).
  11. Install the passenger compartment air filter. Notice the air flow direction indicator printed on side of the filter.
  12. Rotate the locking tabs on the filter housing inward to secure the air filter in place.
  13. Install the cowl screen.
  14. Install the cowl screen nuts, and tighten the nuts to 9 inch lbs.(1 Nm).
  15. Close filter access door.
  16. Install the weatherstrip at rear of the engine compartment.
  17. Install the wiper arm assemblies.
  18. Connect the negative battery cable.
  1. Disconnect the blower motor electrical connector.
  2. Remove the lower blower motor cover retaining screws.
    Fig. Remove the lower blower motor cover
  3. Remove the lower blower motor cover.
  4. Remove the blower motor nuts.
    NOTE Cut through the case as straight as possible because the motor cup must be replaced.
  5. In order to prevent damage to the component, do not cut any deeper than necessary to remove the motor cup.
  6. Remove the blower motor and cup from the lower case by cutting through the case between the circular ribs around the motor with a sharp utility knife.
  7. Release the blower motor retaining tab and remove the motor from the cup.
To install:
  1. Install the blower motor into the motor cup that was cut out of the lower case.
    Fig. Install the blower motor (1) into the motor cup (2) that was cut out of the lower case
  2. Install the blower motor nuts, and tighten the nuts to 21 inch lbs.(2.4 Nm).
  3. Attach the service ring to the motor cup with the screws included in the kit, and tighten the screws to 15 inch lbs.(1.8 Nm).
  4. Install the blower motor and service ring into the HVAC module using the screws included in the kit. Make certain the blower motor electrical connector is pointing rearward in the vehicle, and tighten the screws to 15 inch lbs.(1.8 Nm).
  5. Install the lower blower motor cover.
  6. Install the lower blower motor cover retaining screws, and tighten the screws to 15 inch lbs.(1.8 Nm).
  7. Connect the blower motor electrical connector.
Hope this helps (remember to rate and comment this).
Oct 04, 2010 | 2000 Saturn Ls 4dr Sedan
Need instructions on how to replace the cooling
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Radiator upper crossmember
    • Fan motor electrical connector
  3. Drain cooling system below the level of the upper radiator hose.
  4. Remove or disconnect the following:
    • Upper radiator hose from radiator
    • Radiator fan fasteners and upper clip
    • Fan assembly by lifting upward to clear radiator
To Install:
  1. Install or connect the following:
    • Radiator fan assembly
    • Upper clip and fasteners
    • Upper radiator hose to radiator
  2. Fill cooling system.
Jul 17, 2010 | 2004 Dodge Intrepid
No clear installation instructions for electric box on air vent
Go to their website, they have installation instructions, pretty simple
Jun 19, 2010 | Air Vent (53857) Fan
Looking for instructions or a diagram of how to install a new blower motor on 1999 chevy silverado
1 Disconnect the electrical connector from the blower resistor
2 Remove the blower motor insulating cover screws.
3 Disconnect the electrical connector from the blower motor
4 Remove the blower motor insulating cover.
5 Pull the retaining tab down while turning the blower motor counter-clockwise in order to disengage the blower motor from the heater/ventilation module (case)
6 Remove the blower motor. Install in reverse order.
Feb 18, 2009 | 1999 Chevrolet Silverado 1500
Can't find light kit for altura 68 in.
Last time i bought it from amazon, take a look Amazon com altura 68 light kit. hope this was helpful. cheers
Aug 05, 2008 | Hampton Bay 24002 Ceiling Fan
Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Jul 28, 2008 | Ricoh Aficio AP4510 Laser Printer
KIRBY G4 FAN ASSEMBLY ORDER
First put the gasket on the spacer, thin end to to out, push it down all the way on the motor shaft, then put the nylon washer on, then the fan, metal washer and then the pulley, just snug it, (don't tighten too much just beyond hand tightening). Put the casing, top and handle back on.
Feb 01, 2008 | Vacuums
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
