Question about Microwave Ovens
I have rust on the door. The unit is 13 years old. Does it make sense to sand and paint the door, replace the door, or replace the unit. If sand and paint, what type of primer and finish paint. If replace the door how much will the part be and how hard is it to do? If replace the unit, what is the replacement model number
    Brigadier General:
  • 4,090 Answers
Lots of questions that may be too difficult to help make a decion.
1) Depends on the degree of rust and whether it is inside or outside.
Outside is easier to deal with. Inside it would be subject to heat burning and odour as most are baked enamel finishes and are not paint at all, but a ceramic compund.
Outside can be rust removed which creates its own undercoat as it dries using the rust particles in an altered chemical state. An enamel paint is preferred or even a ceramic based compund.
replacingt the whole door may involve dollars to $100 unless you can find a second hand market for spares.
Frankly, because Microwaves have become so cheap now ( even secoid hand ones) you can pick them up from $50 to 200 depending on size and wattage. i would consider that it has had its time and replace the whole unit. After 13 years of service its time to retire it and move up. Newer ones are more power efficient and better sealed against radiation leaks than the older ones
Please rate my help++++Thanks for using FIXYA
Posted on Aug 01, 2010
Coating inside oven has de-laminated and rust is forming under coating. Warranty?
Hello spark... no warranty unless the microwave is under 1 year. If there is a lot of rust and delamination you are best off to replace this oven.
The problem with delamination is that it exposes bare metal and can result in dangerous arcing.
If it is not real bad, sand off the rust and spray paint it with microwave cavity spray paint available at this link http://www.appliancezone.com/ShowProduct.aspx?ID=8338&AspxAutoDetectCookieSupport=1
Joe
Thanks for choosing Fixya!
Feb 20, 2011 | GE Microwave Ovens
The paint in the cavity of my 6 year old microwave oven is peeling from the top. I don't know why. Is it safe to sand off the loose paint and touch it up?
Sand off the loose paint and make sure that there are no holes in the cavity. If there's holes the unit is not safe to use.
If it's just surface flaking, it should be safe to sand back with fine grade wet/dry sandpaper. We usually respray with automotive paint in a colour close to the cavity colour.
May 26, 2010 | GE Microwave Ovens
Cracked seam inside Microwave
It will have to be sanded smooth and clean and dried thoroughly.
Then if the steel seam is actually cracked / separated, then you can apply a very thin bead of steel-based epoxy "J-B WELD". When it dries thoroughly, you can sand it smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If it's just the paint that's cracked, it will have to be sanded smooth and clean and dried thoroughly.
Jun 27, 2009 | General Electric Microwave Oven
Bottom of door inside badly rusted - oven works fine
Yes you can paint it.. Begin by removing the rust with either a wire brush or a thick paste product called naval jelly. Then prime the area and finally paint it with appliance paint, abailable in a spray can at most hardware stores in the color of your appliance.
May 26, 2009 | General Electric Microwave Oven
My microwave is rusting inside. mainly the area where the turning wheels meet the base. I have sand and painted with microwave paint but after a few weeks the paint area around the wheels is rusting again.
try the microwave touch-up paint again but this time clean the spots you sanded with rubbing alcohol. also make sure the rollers turn freely
Jan 31, 2009 | Microwave Ovens
The door on my Whirlpool 1200 watt microwave has some paint missing on the inside of the door. It's just below the door window. I think my wife had a small fire a year or so ago and she is concerned about...
If the metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you may get rust and/or arcing.
Jan 26, 2009 | Whirlpool GT4175SPS Stainless Steel 1200...
Paint has chipped off bottom of MW
Moisture accumulation can sometimes be caused if the cooling fan is not running properly or if the vents in the back are blocked or there is not enough free space around the sides and back of the microwave.
One thing that helps is to keep the door open a few minutes after using it and to wipe down the inside after use.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Nov 22, 2008 | Panasonic NN-T990SA Microwave Oven
Bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle and Rusted Interior
Hello SusanWargin,
In my opinion ( and that is all it is).. I have always stood by the old litmus test whereby : if the cost to repair is close to or exceeds the cost to replace, then replacement makes sense. From the description you've presented and considering your micro is 12 years old, there is a reasonable chance that other components ( magnetron, transformer et al) will begin failing and end up costing more and more. So.. I would support your decision to replace with a new one. (again, this is only my opinion but I say this with sincerety and some experience with these appliances) ...Good Luck deciding..
Oct 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Rust inside the microwave.
The areas can be sanded and painted, but first make sure there are no holes rusted through. If it's all surface rust, then sand and clean as best as you can. If you have any areas rusted through - get rid of the microwave.
Use the paint sparingly - don't try to cover in one or two coats. Best results are obtained with very, very light coats drying 10 minutes or so (depending on the humidity) in between. 10- 15 coats usually works well.
It's best to do this outside, as you'll have lots of overspray.
As far as the paint - the best I've used for the last 20 years or so comes from A.M.I. Parts. You can find them @ www.amiparts.com or toll free 1-800-522-1264.
Jul 04, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
180 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
