61 RCA THE FULL # IS HD61LPW175YX1.I THINK IT IS THE BALLAST.WHEN I GOT THE TV IT DIDNT COME WITH THE MANUAL.I FOUND THE PROBLEM OF THE COLOR WHEEL,THE TV PLAYED PERFECT BEFORE JUST MADE THE LOUD NOISE.CAN YOU TELL ME WHAT THE FLASHING 5 TIMES MEAN?
  • RICHARD8X5 Apr 24, 2008
  • 8,617 Answers
Your model is an ATC336 Chassis DLP when the LED blinks rapidly 5 times every 20 seconds that is an error code for a defective lamp. Your lamp number is RCA part 269343 you can get one here with fast shipping on sale for 169.00
http://www.purelandsupply.com/GeneralSearch.aspx?search=269343
Let me know If I can assist you further.
Posted on Apr 25, 2008
How do i find the ballast in rca dlp tv
I just had an issue with my rca hd61lpw42, I had replaced the lamp and got the same five blinks you described. I took out the ballast the smaller circuit board, its in front of the light and mounted to the front of the tv. To get to it you remove the back cover with the tv cooled down and unplugged of coarse. Be extremely careful when removing the ballast as it normally operates at about 336 volts dc. its basically no amps but it will still throw you across the living room. The being said I found another site that discussed our issue on the ballast going bad. It is not the whole board that is bad normally. There is a solder joint in the middle of the circuit board coming up off the bigger board and that solder joint normally goes bad and causes the issue. All I had to do was remove the board and resolder the connection and reinstall. But you can get them on ebay for $50. iif you have the money or no soldering experiance I would suggest that route. The site is http://www.ebay.com/sch/i.html?_trksid=p4712.m570.l1313&_nkw=%09+RCA+Ballast+Assembly+%28261629%29&_sacat=0
Now I hope I can keep the light tunnel together :-)
Aug 10, 2012 | RCA HD61LPW42 61" Rear Projection HDTV
I have a hd61lpw165 big screen tv that makes a loud buzzing sound as soon a it goes on with no picture.
sounds like the lamp or ballast, check the lamp first to see if good, then if good, then probably the ballast is bad, but I think the sound or buzzing is coming from the ballast, so it's should be good.
Mar 04, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Jun 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Buzzing
If it is a buzzing noise, it is the Ballast for the lamp.
If it is more of a grinding sound, it is the Color Wheel motor.
Does it go away when you turn off the tv? If so, does it stop abruptly or does the sound tend to get softer (winding down noise)
If the noise stops abruptly it is probably the Ballast.
If the noise takes several seconds and seems to get softer until it stops about 30 sec later then it is the color wheel motor.
Richard Bartlett
Apr 02, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Wont turn on
light engine... lots of money... https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5396908&smodel=HD61LPW42
Mar 19, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
Nov 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 61 DLP
See my last post to you the 5 blinks means defective lamp I included a link where you can get a replacement
Apr 25, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
RCA HD61LPW165 Ballast
This is normal . It is telling me it is trying to turn on the lamp. But are you having a problem with the set now or is this something you've just noticed. If your set is not working check the the lamp or make sure it is seated correctly.
Feb 27, 2008 | RCA HD61LPW165 61" Projection HDTV
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
