Question about Gateway 2520915 Keyboard
I have a Gateway keyboard model number KU-0833. I
I have a Gateway keyboard model number KU-0833. I can only get the French characters to appear. How do I remove this feature.
Hi lal1220,
I had the exact same problem with my keyboard (KU-0883). What you want to do is first go into your "Control Panel". From there under "Hardware and Sound", go to "View Devices and Printers". Right Click on your USB Keyboard and go to "Region and Language". Under the "Keyboard and Languages" tab click on "Change Keyboard". From the "General" Tab click on "Add". Scroll down to "English (Canada)" and expand it by hitting +. Uncheck "Canadian French" and "Canadian Multilingual Standard". Then press "OK". After which you press "Apply" and "OK". Give your computer a quick reboot and your good to go.
Posted on Aug 22, 2010
I connected my Gateway/Acer keyboard KU-0833 &it says there's no driver found, what can I do to fix it?
If you can...download the driver onto your phone from the manufacturer's website, then connect the phone to your PC and use a mouse to browse to the folder and install its driver.
Dec 17, 2017 | Computers & Internet
My ku-1112 gateway keyboard is way too slow...////?
Is it wired or wireless? If it is wireless, make sure your transmitter is close to the keyboard. Also you can try to update your C++ package in automatic update section. Please post back with further information on the keyboard.
Jan 18, 2014 | Gateway Computers & Internet
My pound sign comes up as # and my @ as "
Windows 7 or Windows Vista
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type intl.cpl in the Start Search box, and then press ENTER.
  2. On the Keyboards and Language tab, click Change keyboards.
  3. Click Add.
  4. Expand the language that you want. For example, expand French (Canada).
  5. Expand Keyboard list, click to select the English(United States) check box, and then click OK.
  6. In the options, click View Layout to compare the layout with the actual keyboard.
  7. In the Default input language list, click English(United States) - English(United States), and then click OK two times.
  8. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  9. Click the Language bar, and then click English(United States).
Windows XP
  1. Click Start , type intl.cpl in the Run box, and then press ENTER.
  2. On the Languages tab, click Details.
  3. Under Installed services, click Add.
  4. In the Input language list, select the language that you want. For example, select French (Canada) .
  5. In the Keyboard layout/IME list, click English(United States), and then click OK .
  6. In the Select one of the installed input languages to use when you start your computer list, click English(United States) - English(United States), and then click OK.
  7. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  8. Click the Language bar, and then click English(United States).
How to make sure that the selected layout matches the keyboard Windows 7 or Windows Vista
  1. Click Start, type osk in the Start Search box, and then press ENTER.
  2. Match the keyboard on the screen with the physical keyboard to make sure that the layout matches.
  3. To check the uppercase characters, click the shift key on the keyboard or on the screen, and match the characters printed on the keyboard.
Windows XP
  1. Click Start, type osk in the Run box, and then press ENTER.
Jan 07, 2011 | Dell Computers & Internet
I have a gateway keyboard ku-0833 and its working fine but I spilt a little coffee on it and a few of the keys are stiff to push. Is there a way I can clean it, tried using cotton swabs around the keys but...
You can pry out the keys using a butter knife and use rubbing alcohol to clean the underneath.
if the coffee got into the connectors you might be out of luck.
**THE FOLLOWING IS NOT RECOMMENDED**
When i spilt mt dew on my keyboard i took out the battery let it decharge for 5 minutes. I put it in a pan and poured rubbing alcohol on it and let it sit for 5 min. While it was sitting i swished the alcohol around a little bit so it could flow. took it out and let it dry for about 1-2 hours and it worked perfectly. this is orta used as a last resort
Nov 24, 2010 | Gateway 2520915 Keyboard
My keys on my gateway laptop is not working right
Your keyboard has a "Numeric Pad" on/off button, in order to compress a full-sized keyboard (with its separate numeric-pad, on the right) into the smaller size of the laptop keyboard.
Press that on/off button, to resume "normal" operation of those keyboard characters that are "multi-labelled".
Jun 16, 2010 | Gateway MT3422 RTL Notebook
Changing from french to english characters. For some reason my keyboard is creating french characters on my screen. I must have hit a combination of keys to do this.
This may vary depending on your version of Windows but it should be basically the same: go into control panel, bring up "region and language" then the third tab, "keyboards and languages". The the first button on that screen, "change keyboards". This screen has a drop-down menu with a list of languages such as English - United States (or presumably whichever one you're looking for).
Note I set my control panel view to "small icons". In category view it's under clock/language/region. Hope I was able to help!
Jun 05, 2010 | Gateway 2520915 Keyboard
I have an acer keybooard model number ku-0355 it in french and it does not have an fn button how do you get the third function to work what knob you press on the keyboard
Hi
It is always imperative that you get a keyboard for yuor region .e. US keyboard for US, UK keyboard for UK, you will find if you get a differnt keyboard layout they will be used differently than the normal UK/US ones
If this has been useful please leave positive feedback/vote/testimonial as
this will help me greatly - Thank You again
Feb 13, 2010 | Acer NSK8458AN Keyboard
Logitech cordless desktop mx 3200 laser keyboard - french characters
Its not the keyboard fault but your operating system. I'm going to assume you live in Canada and when you had setup the computer for the first time you had selected Canada has country you live in instead of the United States (default) If you notice on your desktop or taskbar there will be a keyboard logo. Click it and select US 101 keyboard (United states). You get the french symbols because microsoft thinks because you live in Canada you must be french canadian.... stupid eh! They have it selected to mulitlingual Canadian. Select the US English as default and you shouldn't get those french symbols when you really want the shift or question mark key.
I live in Canada and I see looks of people who ask me the same question all the time.
Hope this helps!
Aug 20, 2008 | Logitech Computers & Internet
Keyboard
that means that the keyboard has been set to a different language. On my screen at the bottom right hand is a little keyboard icon and when i click on it it lets me scroll through US English, Canadian French and Canadian Multilingual Standard. If the keyboard is set to the Canadian French option (or whatever other option that is available on your keyboard in red characters) the number two button changes function.
May 22, 2008 | Acer NSK8458AN Keyboard
Gateway 2520915 Keyboard Logo
1,179 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
