Question about Maytag MLE2000 Front Load Stacked Washer / Dryer
My dryer takes multiple runs to try an average load of clothes
  • 4 Answers
Check your vent on the back of the dryer and also make sure the vent hood on your house is opening up all the way. Something could be blocking the air flow.
Posted on Aug 16, 2010
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
I have a 7 year old electrolux edc 5330 clothes dryer. The dryer seems to run normally - there are no weird sounds or error codes. However the clothes dry poorly. I have to run the most efficient drying...
Remove the dryer from the vent leading to the outdoors and try drying a load. This will reveal a restricted external/internal exhaust. If it dries in a normal cycle, it means the duct to the outside needs replaced or cleaned.If it still takes too long, the washer may need some maintenance to make it extract more water. If none of the above resolves the issue, the dryer will need to be disassembled inspected for worn, parts/air seals, etc. Follow the link below for disassembly instructions
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 20, 2017 | Dryers
Dryer makes a loud squealing noise when I try to dry a load of clothes, towels, anything
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 11, 2011 | General Electric G.E. DBXR300EGWS 6.0 Cu....
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
Hello I have a Kenmore clothes dryer (80 series). It takes multiple cycles to dry the clothes.
Remove the connecting vent on the rear and run a timed load 45 minutes. If it dries correctly repair the vent blockage.
Oct 26, 2009 | Kenmore Dryers
It takes usually 3 complete cycles to dry an average load of clothes.
try taking the vent hose off your dryer and running it through a cycle with it off...if it drys ok then you have a clog somewhere in your venting.
Jun 22, 2009 | Roper REX5635E Dryer
Takes multiple cycles to dry normal load of clothes
Have the vent system from the back of the dryer to the outside of the house cleaned. If the dryer can't push air out, it can't bring air in, and the clothes won't dry. Another condition you might be seeing is moist lint developing around the gasket on the inside of the door. That's a sure sign the airstream is restricted somewhere.
Apr 25, 2009 | Dryers
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
Maytag MLE2000 Front Load Stacked Washer / Dryer Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
