Question about Nikon COOLPIX S230 Digital Camera
COOLPIX S220........getting "lens error" when turning on and lens trying to focus.
    President:
  • 1,382 Answers
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Aug 01, 2010
5 Suggested Answers
wildbear6
  • 192 Answers
SOURCE: S220 Coolpix has a lens error problem, turn camera
Did it drop? sounds like the motor is trying to move the lens as you need, but the lens has come out of its tracking. If there is no outside damage and you still have warranty left, you should get it replaced, otherwise it means opening it to place the lens back on its tracking, but this can be tricky.
Posted on Jan 05, 2010
tbreeze47
  • 3083 Answers
SOURCE: When I turn my Nikon
From what you said, it shouldn't be a lens problem, but even dust, lint, and sand can cause problems. The focusing ring works with an electromagnetic field, and that attracts particles. You can try to spray compressed air into the lens assembly to free it up, or give it a medium bump with the palm of the hand, while holding the camera with the lens facing up, then down. This following site tells of other possibilities, and might help:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, and if this helps, please rate it favoribly.
Posted on Sep 14, 2010
dnewcombe1
  • 1564 Answers
SOURCE: my nikon coolpix s220 have
Try removing the battery/batteries and clean the contacts underneath. Also, clean the battery contacts and the charger, if so equipt. To do this, dampen a cotton swab with rubbing alcohol and rub the contacts. Blow into the compartment after to clear any residue.Thanks, Dana
Posted on Jan 03, 2011
  • 138 Answers
SOURCE: coolpix s220.stating "lens error"?
You camera might be in it's last leg. These camera has only so many thousands of exposures and then they worn out. If you are a photo bug I would suggest that you upgrade and get a camera with a higher rating in how many frames it can actually capture. You lens motor is worn out and once that happens it is time to say good-bye. Sorry about the bad news but that is reality. Good Luck
Posted on Jan 07, 2011
My nikon coolpix s220 have a lens error and when i turn it onthe lens goes in and out like its trying to focus and it makes a wierd noise. it also wont let me do anything it just pops up saying lens error
Jan 03, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
When I turn my Nikon Coolpix S220 on, it makes a funny sound and the lens tries to focus. It zooms in, and out, trying to focus but stays blurry. It then says 'lens error' and turns off. I have always...
Sep 14, 2010 | Cameras
Nikon s220 lens error
The s220 seems to be very susceptible to lens errors, usually associated with the lens barrel being unaligned. It only takes the slightest bump/drop in many cases. Fixing it is a hit or miss solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Has a good list of possible fixes.
Jul 06, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon S220. Lens error. Turns on but displays lens error only.. Cannot take pics
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 15, 2010 | Nikon Coolpix 2200 Digital Camera
S220 Coolpix has a lens error problem, turn camera on tries to focus (Lens moves in and out making a weird noise) but comes up with a lens error problem
Jan 05, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Ok ive had my camera for maybe one week its a nikon coolpix s220
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Jul 08, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon COOLPIX S230 Digital Camera Logo
66 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
