Question about Dell Inspiron E1705 Notebook
Inspiron e1705 lcd works only in certain postitions.
The lcd works fine in one position. Move it and it shows lines. the lcd cable has been changed.
Please help.
brianandpatty1@verizon.net
  • Anonymous Dec 16, 2008
    I have a 1" vertical 'white' line down the center of my Dell Inspiron E1705. Is it the lcd Cable?
    Champion:
  • 268 Answers
This kind of job is best being done by a professional, you could possibly have faulty wires, try and find a computer technician in your area, you don't want to leave it too long otherwise the problem might get worse, or if you haven't had the computer that long see if you can get a replacement
Posted on Apr 24, 2008
My dell inspiron m5030 has a white screen any ideas what it is?
LCD video cable. Plus, to connect and activate an external monitor, you click Fn + F2, not F8.
May 20, 2012 | Dell Inspiron M5030 Laptop
Dell inspiron laptop screen colours inverted (negative)
if the same issue occurs in the BIOS your soluton is to have your LCD screnn replace or have your LCD inverte cable checked/replaced ^_^ this has nothing to do with the BIOS vodeo card drivers do not function in the BIOS to be able to do such in the BIOS screen
Jun 04, 2010 | Dell Inspiron E1705 (DNDWGA3) PC Notebook
Hp pavillion dv9000 lcd screen changes colour when moved
The inverter is to change the volts from the laptop to the Backlight. This wont have anything to do with it.
Im more than certian it will be the LCD cable. Proberly loose or torn at where the lid closes.
Hope this helps.
James
Feb 23, 2010 | HP Computers & Internet
Dell Inspiron E1705 does not show any picture
First of all, check that the laptop is set to output video to the LCD. There should be a function key which will determine whether it is outputting video to the built-in LCD, the external monitor, or both. That should be holding down your "FN" key and hitting "F8." If it is on CRT ONLY, it should switch within 1-2 keypresses.
Secondly, take a good bright flashlight and shine it directly at the LCD panel from about 1-2 inches away. If you can actually see the graphics on the screen faintly in the background, your backlight is not turning on. The backlight is literally a bulb which lights up the screen, and they can burn out. It is repairable, and shouldn't cost more than $150.00 from a reputable repair shop.
Sep 01, 2009 | Dell Inspiron E1705 Notebook
Hdmi to dvi connection
settings you need to change the Display Adapter option, can be set as dual mode or, access the control panel and find the display settings
Jul 22, 2009 | Dell Inspiron E1705 Notebook
Where is the LCD backlight inverter on an Inspiron
The inverter is in the LCD, below the actual screen. It controls the brightness and the contrast on the laptop. Here is a link where I purchase them:
http://www.smartmicrousa.com/dell-inspiron-e1705-laptop-inverter-board.aspx
It is easy to replace. Here is a link that will guide you:
http://www.ehow.com/how_4841734_dell-laptop-inspiron-e-backlight.html
Apr 21, 2009 | Dell Inspiron E1705 Notebook
Loss of light on screen Dell Inspiron E1705
Check your backlight settings, Power Settings, etc.....
You may have Vista (vista has other power settings such as a custom sleep mode which can fail sometimes to work properly with some hardware/monitor configurations).
So Disable any unconventional Hibrid Hibernation options k!
Apr 20, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
Looks like the backlighting on the display has failed, sometimes it is just a lose cable, buy most often the LCD needs to be replaced.
to check the cable see the manual at http://support.dell.com/support/edocs/systems/ins9400/ for how to get to the LCD cables (usually just under the cover that the power button is on)
Jan 27, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Laptop E1705 Screen goes Blank
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is have the LCD panel replaced. The ribbon cable that plugs the LCD panel into the motherboard could also be the culprit. Here's a link to the display assembly for 1501: http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/display.htm#wp1022270
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Jan 09, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron E1705 Notebook Logo
Alun Cox
