Question about HP PSC 2410 All-In-One InkJet Printer
Scanner not connected & I don't have the disc to load
I have replaced my PC since buying the HP Printer and the scanner isn't connected. I don't have the disc any more. Can this be done via internet please?
  • 820 Answers
Hp printer 1312 fadad print how to fix
Check any refilled cartridges?.. No.Go to main menu select default setting.. check for the quality..No..
Need to clean reflecting mirrors in scanner assembly..Only professionals can perform this activity..
Remove right, left & back doors..
Detach the cable which came from flat bed assembly, remove two screws back side just below of flat bed, gently push flat bed assm back to front, lift & take out the flat bad unit.. remove upper cover, you can observe the scanner assm ( see the snap shot) "Note: to take out scanner assm cartridge & cartridge bank must be present in to the printer to prevent the damage to transfer kit, other wise scanner will fall down on transfer belt" Unlock & remove scanner secure pins(4nos), detach scanner flat cable connected to DC controller, take out scanner assm, open the bonnet of scanner assm, clean surface of the mirrors very very gently with ear buds.Don't disturb any factory settings, once its cleaned refix every thing back.. "Note: scanner flat cable which is connected to DC controller is not that much lengthy, before powering on check once cable connected in properly or not, if any thing goes wrong in this area printer wont power on & it may damages the DC controller or scanner assm .." But I am sure that only professional can perform this activity, if you are not qualified pl don't try it..5_25_2012_8_24_06_pm.jpg
May 25, 2012 | HP LaserJet CM1312 All-In-One Printer
Hi Buddy, Can you help me with my HP printer? I keep getting a Scanner Error 8 message and it won't print. Time to buy a new printer?
Make sure the scanner usb and power leads are securely seated
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similiar options also have option to troubleshoot
HP PRINTER DRIVER PACKAGES
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
hope this helps you
Nov 16, 2011 | Office Equipment & Supplies
The printer is added but the scanner isn"t
Might be the driver cd not supporting the OS,..down load the full feature drivers from hp site,install it & check..
Oct 04, 2011 | HP LaserJet 3030 All-In-One Printer
HP M3027X - has 52.00 error code. We replaced the scanner but the error is still there. Any suggestions?
1. Verify that the laser/scanner motorconnector and the ribbon cable fromthe ECU are firmly seated on the laser/scanner assembly.2. Verify that the laser/scanner motorconnector is firmly seated in connectorJ402 on the ECU. You might have toremove the main cooling fan to seethis connection.3. Verify that the ribbon cable installed inconnector J403 on the ECU is fullyseated. You must remove the ECU inorder to verify this connection.4. If, after checking the cables, themessage persists, replace the laser/scanner
5. If, after replacing the laser/scanner,the message persists, replace theECU
Replacing the ECU isn't pretty. If you haven't done it before, you probably should get someone that has.
Sep 30, 2011 | HP LaserJet M3027x MFP Printer
Hp 3005 kod 52.00
Laser/scanner error. A scanner motor error occurred. It probably isn't spinning.
A printer tech is needed to replace the laser/scanner assembly.
Apr 21, 2011 | HP LaserJet P3005 Printer
QUIERO INSTALAR ESCANER HP SCANJET 4470C Y AL INTRODUCIR RL CD ME DICE QUE YA NO ES COMPATIBLE ¿QUE HAGO? POR FAVOR. Eduardo
Hi Eduardo ,
Go to HP site http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?sw_lang=35&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=60679
Select your operating system and download driver .
If you don't find a compatible driver in the list , you can make your scanner run in WIA mode :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekature , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Otherwise , you will have to buy a new scanner .
Regards
Dec 04, 2010 | HP Scanjet 4470c Flatbed Scanner
Have HP scanjet loaded software and driver but it just does not work checked electrical connection and usb ok thought it had gone wrong so bought new HP g2410 still cannot load checked hardware manager...
Having re-read your post it seems you have a visioneer scanner and installed HP scanjet drivers so this would definitely be an issue.
Ok, unplug usb lead between scanner and pc.
go into add/remove programs and remove any scanner software that may be showing.
load correct scanner driver (preferably the latest version from the manufacturers website).
plug in scanner usb lead when prompted and turn scanner power on.
It should then install correctly.
If usb stuff starts playing up it's usually easier to unplug it, uninstall it then re-install it using the latest drivers from the manufacturers' website. Don't just stick the disc in and re-install. Can save hours of messing about.
Apr 28, 2010 | Visioneer OneTouch 5800 Flatbed Scanner
Hp officejet 6500 all in one, scanner suddenly quit working, small office network only two pcs, printer function works, but scanner says no connection? Removed HP driver, Reinstalled whole thing from Hp...
The scanner has a separate driver. Go to Device Manager and click "Imaging Devices." Is the scanner there? If yes, try to update driver. If it's not there, right click and select "scan for hardware changes." Plug and play should see the scanner and install it. If not, go to control panel, hardware, add device. Keep the disk in the machine, as you know it has the drivers on it. If there is a newer driver online, you can update later.
Aug 13, 2017 | HP Officejet 4315v All-In-One InkJet...
My HP officejet J4580 All in one scanner is not working, when i go to scan it tells the computer does not reconise a scanner, i have lost the disc for it, where do i go for the down load.
Here is the main support page for your printer:
HP J4580 Support
For documentation click on Manuals. For the driver and other software click on Software & Driver Downloads. Then click on your operating system for available software.
Thanks for using Fixya.
Oct 07, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP PSC 2410 All-In-One InkJet Printer Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
