Question about kawasaki Sport & Outdoor - Others
1994 kawasaki 750 xi jet ski wont rev up but idles fine
4 Suggested Answers
SOURCE: 06 kawasaki jet ski wont start
Check the fuses! I have two 900zxi's brand new batteries and brand new plugs,
Fuses are in the electrical box under a black cap(depending on model)
Posted on May 10, 2009
heimlich
  • 1978 Answers
SOURCE: 1995 kawasaki 750 jet ski
Check your plug color. You may be having a high speed mixture problem. Is your ski spitting water out the tiny hole on the side? You should try flushing the engine, you could have a motor full of sand if you beach the craft but do not wash the sand out of the back before starting. Also inspect the engine water tubes for cracks. From the hull to the motor and from the hull to the jet pump.
Posted on Sep 03, 2010
heimlich
  • 1978 Answers
SOURCE: my jet ski starts fine, goes slow, when i give it
You are dealing with moisture in your electronics box or moisture corrosion in you carburetor. Take you carburetor apart and clean it . Make sure the needle is not sticking and do not alter the spring in any way.
1994 Kawasaki VN 750 Vulcan will not run without choke
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.vn750.com/forum/22-carbs-fuel-system/50473-will-not-idle-without-choke.html
Runs only with choke Fuel problem Kawasaki Vulcan Forum Vulcan Forums
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
1995 Kawasaki Vulcan 750 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 18, 2014 | 1994 kawasaki VN 750 Vulcan
Jet ski troubleshooting
damaged impellor or housing , grabbing air !
Dec 19, 2013 | WSM 1995-1997 Kawasaki 750 Zxi Cdi...
My 1994 kawasaki 750ss jet ski has very low compression in one cylinder how do I repair?
Since this is not a computer game, you might want to repost in the correct catagory.
Jun 01, 2012 | Video Game Consoles & Games
I have a 1995 kawasaki ts jet ski it runs but goes really slow will not hit high end. i just got this jet ski it looks like the carb and lower end of motor is new. i did find some water in carb and cleand...
If the carburetor was properly cleaned including the teeter-totter float needle then you may just have accidentally changed the setting screws. Try setting the the high end and low end adjustment screws the standard settings are: Low speed screw: 3/4 turns out (+ or - 1/4 turn for fine tuning) high speed screw: 1 1/4 turns out (+ or - 1/4 turn for fine tuning) If the previous owner rebuilt the whole machine but could not figure out why the boat would not rev out, the next thing to do is remove the water box and and split the halves. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch27834 If a mouse nest has been built in the exhaust system the extra back pressure could be the problem. If the exhaust coupler has broken rubber tubes, has come apart, or has not been put together correctly that might also be the cause of the problem. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch29444
Aug 08, 2011 | kawasaki Full Suspension Mountain Bike Men
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
I have a 1994 Polaris jet ski slt 750 that will start up when it's out of the water but when I put it in the water it won't start. It just started doing this. I had the battery checked and was told it was...
You are deal with moisture corrosion in your carburetor. Take the carb off and clean it paying attention to the corrosion on the rubber tipped needle. Also open your electronics box and make sure that it is dry.
Aug 08, 2010 | Encore Software Kawasaki Jet Ski...
My jet ski starts fine, goes slow, when i give it gas the rpms rev high but it wont go any faster than the low idle speed
Jun 16, 2010 | kawasaki Full Suspension Mountain Bike Men
PlZ PLZ HELP kawasaki jet ski with fuel issues
Take your carburetor apart and clean it. There is moisture corrosion that is keeping the needle from moving. Be careful not alter the little teeter totter spring in any way.
May 15, 2010 | Encore Software Kawasaki Jet Ski...
Sport & Outdoor - Others Logo
302 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Marvin
Marvin
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
