Question about HP G60-230US Notebook
G 60 White screen and freezes
Hp G 60 gets a White screen and freeze?
  • 2,632 Answers
You can try to do a System Restore the laptop and bring it back to the state that it is working properly or you can also use the Recovery CD, You can do a Clean Install as well. The computer might be infected by a virus, spyware or malware that messed the compter
Thanks for using Fixya
Posted on Aug 01, 2010
White Palm Centro freezes randomly. Doesn't respond to input
http://forums.palm.com/t5/Support-Downloads/Palm-Centro-ROM-Update-for-Freezing-Issue/td-p/165101
Mar 28, 2010 | AT&T Palm Centro Cell Phone - White
Freezing at the "HP iPAQ Pocket PC start-up" and won't advance any further. (think that it pushed up against something in my bag, and perhaps maxed the memory?). Not at a point where ActiveSync can...
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me
Jul 25, 2009 | HP iPAQ RX5915 Travel Companion GPS...
Game screen freezes and there are white vertical lines on the tv
i dnt know about the vertical line but i had the same problemand i solved this by taking it to my nearest computer shop its as simple as that
Apr 14, 2009 | Microsoft Xbox 360 Console
Freezes at whight screen
Don't use the Action Replay. It messed up my friend's ds.
Feb 21, 2009 | Nintendo DS Lite Console
Phone continually goes to white screen, freezes, turns on/off
hi insane,
ur phone needs to b re-flashed. i.e its file system is corrupt. if u r not a techie guy then better take it to an repair center. otherwise chk this site out: mobilejunkies.net
this will work it out. good luck!
Jan 02, 2009 | Sony Ericsson W300 Cellular Phone
Computer freezing- blank white screen
Check your connecting cables to the monitor. They can become loose or you may have a cracked cable.
Jul 13, 2008 | HP Computers & Internet
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Video freezes up to vertical lines or blue or white screen
Clean the CPU cooler and everithing else from the dust!
Turn off,open the case, use air spray to clean.
(I use vacom cleaner and a small brush, but you risk your component if you do the same! I'm professional.)
Nov 27, 2007 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
HP G60-230US Notebook Logo
264 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
