Question about Minn Kota Boating
My Johnson Escape boat w/ Minn Kota engine stopped running
My Escape boat w/ Minn Kota engine stopped running properly. The prop turns in all the speed settings in both the forward and reverse directions but seems to have lost all the torque. Any hints as to how I should trouble shoot this
I've had the same problem. It steams from the control panel. I took and ran a seprate ground wire directly to the motor. This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to replace rotary switch and circuit breaker. These also are trouble-some parts.
Posted on Sep 15, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minnkota endura c-50 shear pin size
    You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
    Trolling Motor Replacement Props Minn Kota Motors
    You will find prop nut kits here just follow the link.
    Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
    Minn kota trolling motor has forward but no reverse
    Don't know what Minn Kota you are talking abut but my 55 pound Thrust one does NOT have a Reverse.... When I want reverse I swing the Prop all the way around so it is pulling the boat backwards..... I just checked it to refresh my memory......
    May 08, 2014 | Minn Kota Boating
    I want to mount my endurac2 on the back of my boat but the handle an the prop are in the same direction is it possible to turn one or the other
    Not entirely sure with your model but it is possible to take the head off (where the handle is) and spin that 180 degrees. You may also check an aftermarket prop that has opposite blade direction. So where normally it's on the front of the boat, pulling through water it's now pushing the water when moving to back of boat. Shouldn't be hard to locate
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
    Apr 04, 2013 | Minn Kota MinnKota ENDURA C2 30 30"...
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Got the Endura 30 from my wife for Christmas. Hooked it to the boat,a 12 foot MirroCraft and tested with battery and overall check, looks good so far. First time in the water on Monday, May 24, made it 30...
    have you called the dealer or returned to the store your wife bought it from. they should be the ones to warrenty the motor. if she bought it used then you need to buy the necessary parts from a suitable store and move on. minn kota is a good company and they make a good product. i do understand your frustration. you might ask for a manager at minn kota if your wife brought it new and she if you can successfully get a better answer on an appeal. good luck.
    May 28, 2010 | Minn Kota Endura 30 Freshwater Transom...
    Have a serial # for minn kota trolling motor but is pretty old like 80's trying to find a parts diagram/prop serial is MK00367970
    Have you tried online with a "Minn-Kota" search? There are also Blogs with various titles that can help.
    Mar 12, 2010 | Boating
    Have a 3 hp. minn kota, prop wont turn, hard to
    I have the same trolling motor and the same problem.
    It seems the factory grease gets hard inside the motor where the shaft spins and acts like glue. I removed the long screws, carefully pulled the case apart, cleaned out the old grease (which was more like hard plastic) and packed the bearing area with lithium grease. I also lubricated the "O" rings and they were not damaged or brittle so I re-used them and put the unit back together being careful to tighten the screws properly. I have had no problems since. Also be sure to check the connections to the battery, for some reason that motor is very sensitive and wants a really good connection to the battery posts and sometimes all you need to do is re-tighten the connection if the motor does not run at all.
    By the way, I contacted Minn Kota regarding the 3Hp and was told "hp" stands for high performance and the motor is not 3 Horsepower.
    Jan 19, 2010 | Minn Kota Boating
    Boating Logo
    302 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
