Question about GE Washing Machines
Have GE washer (model WBSE2090A0WW) with bad controller assembly. The new part (GEH part no WH12X10176) is different than the old part in that it has an extra circuit board on it that extends out another 7 inches and has two more places for knobs. GE assures me it is the right part. It also comes with two rubber caps and springs. What are these for?
2 Suggested Answers
SOURCE: GE washer model WBSE2090A0WW control assembly replacement
hi. I was also searching for the same part and got the same result; nooo, the unit is smaller and only has spots for two knobs not four.
have you looked at this site? https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=PARTSRESULTS&AppliancePart=Washers and Dryers_Miscellaneous .... if that link doesn't work try this and navigate thru it.
There is a guy who lives down the street from me who owns an electronics repair shop; I will be taking my control assembly to him. I'll let you know what he says. On my circuit board, there is a "brown" solder joint; all others are the normal silver color. Hopefully the guy can fix the component that hooks up to the solder connection (it's a relay).
I've been having trouble w my washer (same model as yours) for a couple months ~ I've troubleshooted everything!!!
Hopefully we don't have to end up buying new washers!! take care. (I'll let you know what my neighbor says, too ... thx)
Posted on Jan 04, 2010
What does a ge control assembly do
The control assembly does everything except temp. on most washers it tells the washer when to fill how much to fill when to empty when to spin etc. You need a new control assembly or a different washer.
Jun 21, 2014 | General Electric WH12X10226 Control...
My GE washing machine stops agitating for quite sometime and then will restart sometimes on its own or when I lift the lid. It is a WBSE209oA0ww
Ok thanks for reposting with the model number,
Now then my other question is; does it spin without pausing such as it pauses in the agitation mode??
If yes it does also pause in the spin mode i would suspect the lid switch as being the problem,but however you did not mention that it pauses in the spin i am going to assume it spins fine and thusly believe the problem with it pausing only in the wash mode is going to a problem with the main control board,sincein the past on that exact style washer the water level part of that control board would think it wasn't full of water and pause while it finally determined that the water level was correct and start again. By replacing the control board the washer should work fine and no longer pause in the wash mode.
The part number for that control board is WH12X10176 it could be purchased at your local appliance parts store or online at
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Oct 13, 2011 | Washing Machines
Brand new GE washer only 2 yrs. old stops agitating and spinning. Model #WBBR3NOG2WW. Any help provided would be greatly appreciated.
Probably a bad timer/module control assembly. It works for a short time then the metal contacts get hot and "open up". The timer control mod is what's behind the big knob. About $90.00.
Nov 01, 2010 | General Electric WJRR4170GWW Top Load...
Installed new control asm on ge washer wbse3120b now all the lights are flashing and no power?
On you old control there was a plug with just a jumper wire. This is the model select plug. Without this plug the washer does not "know" what model it is on and the lights will flash. http://www.appliance-repair-it.com/ge-washer-lights-blink-after-replacing-the-control-board.html
Sep 13, 2010 | GE WBSE3120B Top Load Washer
Jan 02, 2010 | GE Washing Machines
GE top loading washing machine (WBSE2090A0WW) stops spinning
it sounds like you know how to remove the frount panal,remove the frount panal.put unit in spin,look to see if belt is turning,if it is not than you have a bad cluch.
Dec 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer model WBSE2090A0WW HELP
Sounds like your loosing your cycle timer which controls all the relays.I would try buying a used one just as a test.
Feb 21, 2009 | GE Washing Machines
Does not start
Either your control is bad (part number - WH12X10176) which is part of the control or the lid switch (WH12X10141) is bad
Feb 18, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
97 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
