Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
What is the setting ryobi 77 weedea for spak plug champlion rdj7y
What is the setting ryobi 77 weedeater
  • 284 Answers
.030
Posted on Aug 01, 2010
Need to repair Ryobi Weedeater Mod.# RY30120 starting pull cord.
What size Torx tool do I need and is the screw that holds the Clutch Drum a right or left hand thread.?.
Hopeton.
Posted on Aug 15, 2010
    President:
  • Ryobi Master
  • 1,545 Answers
.025" is a common setting for most all of these units
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: My Ryobi 77 line trimmers revs like mad when I
Hi and welcome to FiXya. I am Kelly
What your describing it the result of fuel starvation. This can be caused by:
1. Debris in the fuel line or a crack in the fuel line
2 A clogged "fuel tank" internal pick up hose screen
3. A pinched fuel line
4. A clogged needle jet seat
5. A hole in the carb diaphram
6. Debris in the fuel air mixture screw / needle passages
7. A non vented gas tank cap.
Any of the above can cause the symtom you described. For sure it is a fuel supply problem.
I tried crossing the part numbers for just a Ryobi Model 77 and was unalbe to cross it to a working model number.
I came up with 2 different carb part numbers using a 30 CC engine
1st PN: 791-182875
2nd PN: 985624001
If you can pass the exact Model Number, I can provide you with a source for the carb or parts.
Thanks for using FixYa.
Kelly
Posted on May 03, 2010
Asbestos 56
  • 191 Answers
SOURCE: wish to purchase sparkplug rdj7y
In the US hardware stores (DIY stores) or stores that sell car parts. Bring the old one in so that you can match the numbers. Also you will need to set the gap. that is the space that the spark goes across. It should have that number in the manual. I can tell you because we use thousandths of an inch. in the US.
Posted on Jul 03, 2011
Can I use champion rdj7y spark plug instead of rdj7j on my craftmans 25cc weedeater?
It is not advisable since the plug has a dedicated design and function.
Jul 14, 2015 | Garden
Wish to purchase sparkplug rdj7y for ryobi blower vac where do i purchse from which australian store please female buyer help!
Jul 03, 2011 | Ryobi 18v P2002 String Trimmer P2102...
Sparkplug gap for a 31cc ryobi weed eater
If its a 725r ryobi weed eater it takes a champion RDJ7Y with
a gap of 0.020 in. or (0.5mm) with a feeler gauge.
torque @ 110-120 in.lbs. good luck!
Jun 28, 2011 | Garden
Bought new e3 plugs for weedeaters and cant find gaps for them i have a Featherlite 20cc Fl20 and a Ryobi 31cc 700R
The gap for the Weed Eater 20cc engine can be set @ .025". The larger engine Ryobi 31cc/32cc class can be set @ .030" Either engine would operate within that .005" range and I know a 32cc Poulan calls for a .030" gap.
Jul 09, 2010 | Garden
What is the spark plug size and gap? ryobi weedeater 700r
The "Champion" spark plug for your item is #RDJ7Y
Or another brand, "NGK" #BPMR6F/130-769
You can set the gap to .020"
Hope this helps...
Sep 25, 2009 | Garden
My grass scorpion willn't start,I have changed fuel with a new mixture & spark plug,still no start & plug wet with fuel & exhaust.Any help to the problem appreciated-dealer give me DJ8J spark...
To make sure that you have the right plug,you need to specify the make and model number of your trimmer.The first thing you need to do is check and make sure you have spark to the plug.
Set the trimmer down.Take out the spark plug.Put the plug into the plug boot and set it on top of the motor.Make sure the switch is on,and pull the recoil a couple of times.Look at the end of the plug to see if you have spark,and make sure it is blue.
If you have spark,you might have a problem with your carburetor settings.
Sep 04, 2009 | Ryobi Garden
RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Jul 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi ss30 weedeater,if weedeater is flooded
If the spark plug is very wet, place the base of the plug against a metal part of the motor, with the sparkplug wire attached to the plug, and pull the starter rope, looking to make sure that the plug has a spark. If it doesn't, that is the problem and it may be that the breaker point gap has to be adjusted or the capacitor (condenser) has gone bad. It is not easy for folks with the typical tools of a homeowner to fix either of these problems, but it can be done. If the spark is good, pull the starter about ten times with the plug out to clear out the excess gas, dry out the plug and put it back in, then try to start it. Too much gas on the plug could indicate that you are pressing the primer bulb too many times or that the fuel adjustment is set too rich.
Jul 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
Jul 11, 2009 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
338 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
