Question about Canon Imagerunner 1025IF Grayscale Copier
My canon imagerunner 1025if is saying that I have to load paper tray A4??? Dont know why this is - never done this before
Cartridges
Presuming you meant replacements: https://www.google.co.uk/search?es_sm=122&q=canon+imagerunner+1025if+toner&oq=Canon+imageRUNNER+1025iF&gs_l=serp.3.3.0i71l8.0.0.0.3519.0.0.0.0.0.0.0.0..0.0.msedr...0...1c..62.serp..0.0.0.3GiocfNTNIM
Mar 21, 2015 | Canon imageRUNNER 1025iF
Canon ir 2420 every thing are good but printer display : load correct paper A4 Plaint copy.
Dear
If you have done all the things, there might be problem with hardware. If the display shows after the paper taken from tray, then replace the paper size detection switch inside the tray.
Thanks.
Jan 20, 2015 | Canon Office Equipment & Supplies
We have a Canon ImageRunner 3035 that won't stop beeping? Please help.
What does the display say? I would check the paper trays first. There is a dial on the front right after you open the tray. This has to match the orientation of the paper in the tray.
May 21, 2012 | Canon imageRUNNER 3035 Black and White...
My canon ir 2018 is asking me to load correct paper in the tray even when the paper size is correct and all the settings are correct. It would print one copy then ask to load paper, i pull out the tray and...
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Sep 16, 2010 | Canon imageRUNNER 2000 Copier
Wont load paper into A4
Ok the problem is in printer driver settings. You need to open printer driver properties, and set paper size to A4, default sett. is LTR.
Hope that helped
Jul 16, 2010 | Canon Imagerunner 1025IF Grayscale Copier
Canon ir3300 not communicating with microsoft windows getting error: printer load paper but trays are full. Can you help?
Under printer properties check the format of paper, it must be A4 if you have A4 in drawer. The most common fault is that under printer properties is LTR as format and A4 in drawer.
NOTICE: in paper drawer did you check the little blue wheel, is it "telling", the appropriate format as in the drawer?
Jan 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
In A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Jan 12, 2010 | Canon imageRUNNER C3200 Copier
Canon Image Runner 210S
The problem could be that on the side of the blue nobe. On the same side there is a small white switch. Switch from A-B to the US/ english. I would just switch it the other directions. That should do it for you.... Unless you have the dial in the wronge place..
Oct 07, 2008 | Canon imageRUNNER 210S Copier
When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t want that to happen cause we print in bulk! When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t...
Hello Uncle123,
I don't have a user manual at my fingers, but you can go into "additional functions". I don't recall if it is within the"common settings" tab or "copy settings" but you can designate any paper tray to be "unique". For example you can designate tray 2 as "colored paper, or recycled paper" .In which case, if you are feeding from tray 1 and it runs out the copier now knows that tray 2 has a type of paper that is different than the current run.Even if the paper size is the same. I hope this helps. Take care. ..............................spinal.........................
Feb 22, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon Imagerunner 1025IF Grayscale Copier Logo
659 people viewed this question
old marine
old marine
