Question about Echo Garden
Were is the serial number located on an echo srm 2400 weed trimmer? it has a 23.6cc engine and some numbers that do not say model or serial number. they are 661725 type 1-E
#1 Taper
  • 1041 Answers
SOURCE: Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
  • 10 Answers
SOURCE: What is the correct ratio for fuel mix for a ECHO
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Posted on Sep 05, 2009
  • 1126 Answers
SOURCE: i need an instruction manual for echo srm 225 weed
http://www.echo-usa.com/documentation.asp?Model=SRM-225&lang=E
Hope this link helps.
Posted on Sep 08, 2009
  • 87 Answers
SOURCE: need to replace the trimmer head cutting line.
Did you try pushing down hard and turning @ the same time? that should do it.
Posted on Oct 05, 2009
SOURCE: location of engine serial number
atras del amortiguador trasero, alli esta el numero de motor,,,
Posted on Apr 13, 2010
How do you tune a carburetor on a Echo Srm-211 weed trimmer?
search--- workshop manual for Walbro carby
search for --workshop manual for ZAMA carby
there are pdf versions for download and both are excellent manuals for all small engine carby , repair , maintenance and adjustment
May 13, 2018 | Echo Garden
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
SRM 2400 trimmer. Why doesn't it start?
Ralph, if you are getting fuel, spark and have compression , I suspect the muffler screen is plugged. Check the attached links,instruction and guides, Good luck
Small Engine Repair Cleaning Carbon Buildup on the Exhaust Port Muffler on...
Echo trimmers and loss of power EXHAUST PORT CLOGGED
Symptoms Repair Of Clogged Spark Arrester On Grass Trimmer
My Aunt Echo PB 2100 Blower with Clogged Spark Arrestor Screen
Apr 17, 2016 | Echo Garden
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 | Echo Garden
Stihl power pruner serial number
The serial numbers on the FS130, HL90K,HT101 and BG55 would be on stickers if they are still there... The MS250 serial numbers are located on a 'flat' by the side of the exhaust and sprocket cover. (depending on the year of manafacture)
Jun 27, 2013 | Stihl Garden
How to add line to an echo srm 210 weed trimmer
See pages 27 and 28 of the owners manual here:
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
This certainly explains it better than I can.
Oct 01, 2010 | Echo Garden
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
Garden Logo
116 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
