Question about Phoenix Gold Ti500.4 Car Audio Amplifier
Amp was being unhooked friend let power tuch ground amp is in protest mode any idea how to fix I checked all fuses they're ok
  • icebergexoti Aug 01, 2010
    I have zero guage ground that all looks fine
    It's a rsd 500.4,I hooked up a different amp and it works fine so must be something internal I guess sound fixiable?
  • 229 Answers
Check the ground. I would make it a stout wire wire as well. at the least 4 guage.
Posted on Aug 01, 2010
Testimonial: "very helpful thanks alot"
  • Jose Velazquez
    Jose Velazquez Aug 01, 2010
    The only other thing I can tell you is to unhook your power wire to it and run a straight wire from the battery to it see if that is the problem. It is possible that him touching the hot wire to the ground caused an arc and that arc caused the short. It is possible that your remote wire could have been affected as well. Let me know if any of this helps. Also let me know what model the AMP is ill do some research n this end
  • Jose Velazquez
    Amps are a tricky thing. They are designed to take 12v DC and transform, step it up, rectify it and then finally have an output. There are hundreds of capacitors, and diodes in there. I had a printed circuit board on my instrument cluster and one of the traces were burnt out, just one and it threw the whole cluster off, No lights, inaccurate guage readings, the works, I mean there were at least 20 traces on the back of that things and just one being burnt up caused all this. I hate to say it but your friend is lucky that he didnt short your entire electrical system. I had a buddy that didn't have a clue how to wire up a stereo and he shorted his entire main harness by grounding out the hot wire. Sorry I couldnt help more, sounds like your friend is going to be in the market for an amp to give to you. Good Luck
How to get amp out of safe mode
first check all connections, fuses and speaker wiring. Check to make sure that the amp is getting enough power to keep it running, meaning a piece of 4 to 8 gauge minimum wre from your battery to the amp. Make sure no wires are touching ground on the speaker outputs all the way to where they connect to the speakers. You can check this with a Ohm Meter to see if their is a direct short to ground. Or unhook all speakers and 1 by 1 touch them onto the amp to see if it cuts out. If the amp is going iinto protect mode without any speakers hooked up to iit (I have a bad keyboard sorry for the extra or missiing I's) and all other things I mentioned are OK then your amps bad and needs to be serviced. Hopefully It's just be a shorted speaker or wire.
Aug 07, 2013 | Jensen XA4100 Car Audio Amplifier
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
How do i password protect our copies?
you can protect your copier with user code protection just fallow theis steps 1. Press the User Tolls Button 2. Tuch the System Settings 3. Tuch the Keyoperator tools 4. Tuch the User code managment 5. make copier ON & tuch OK 6.Tuch Next and Tuch Addressbook Managment 7. Tuch new program 8. Tuch User Code 9. Enter the number your choise & Tuch the # 10. Tuch the function Eg. Copier & Tuch the OK and Exit the user tools - thanks
Oct 29, 2010 | Gestetner DSm745 Black and White Copier
Old Amp blew, got a new one. Power light came on but speakers didnt work. Unhooked the amp, hooked it back up and no power. Any ideas?
Are the speakers still working? When the old amp blew it might have blown the speakers too. Are any of the wires grounding out besides the ground? I would check the remote wire too. I also suggest replacing it with a bigger (smaller #) gauge wire, its not as sensitive to interference and gives your amp a boost in actual power to the speakers. Check any fuses to see if they are blown. Make sure all the connections are tight. If no power after this all checks out then amp is blown again and you might want to get smaller speakers or a bigger amp (or better).
Aug 11, 2010 | Car Audio & Video
I have a alpine mrp-m500 for about two years no problems at all. but one day it stops producing sound. i check all fuse on the whole system. is the a protect mode? and how do get it out of it?
If you have checked all the fuses.
Trace your ground wire that goes to the frame. It may be possible your ground is no longer grounded properly. You may just need to unhook the fuse from the battery, Unhook the ground wire from the chassis and restrip, put on a new connector, chisel off the paint around where the amp was grounded to and tighten it back down. Hook back up your fuse to the battery and check and see if it removes the protect light.
Also check to make sure your RCA cables aren't bad. If the RCA cables ground it'll put the amp into protect mode too. Basically just switch out the RCA cables for a good pair.
If the remote wire on the amp is touching the ground, it'll throw the protect light too. That's pretty much the extent, unless the amp has a short inside it.
Hope this helps!
Jul 26, 2010 | Alpine MRD-M500 Car Audio Amplifier
I have checked all connections to my amp battery,head unit,remote or trigger wire,fuses,power cable,rca leads,ground wire,amp has a green led light on it indicating if it works ok,red if it`s not,light...
Your amp could be in protection mode! Sometimes turning up to high or wires touching will put in protection mode! It will have to be unplugged for a day or two to drain all power out of the memory. Leave accessorie/ignition wire hooked up, just not power and ground wiring. It should reset itself.
Jan 22, 2010 | Lightning Audio B4.250.2 Car Amp
Amp stuck in protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Good Luck.A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 22, 2009 | Power Acoustik Car Audio & Video
Protection light stays on
not unhook the amp completely let it sit for 15 minutes it should reset it self and rehook the amp starting with ground rca and remote than the power last it should be back to normal
Apr 20, 2009 | Directed 2400d Car Audio Amplifier
Help!!!!
Check your ground wire! Relocate it to another place in the car and try to get a heavier ground wire aswell.
Apr 03, 2007 | Sony XM-2200GTX Car Audio Amplifier
Phoenix Gold Ti500.4 Car Audio Amplifier Logo
70 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
