Question about Samsung HCN653W 65" Rear Projection Television
Hcn653w was fine last night,turned it off and a short time later I turned it back on to find the whole top half of screen yellow and blue ghosting
    Scholar:
  • 137 Answers
Hello pk95953,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Posted on Jun 22, 2008
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Samsung HCP4752W convergence board?
I couldn't decide whether or not to attack the IC Chips or the whole board, so I took out my S&W model 59 and pumped 11 9mm rounds into the whole chassis! Sets works as new as long as 'new' means comes with 11 bullet holes in chassis.
May 12, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Color convergence problem
If you follow the instructions on the other thread, you should be able to resolve the problem. Try the simple stuff first. Resolder the pins of the convergence ICs and see if that alone resolves the problem. Sometimes that is all it takes.
Keep us posted.
Dan
Jan 30, 2009 | Mitsubishi WS48511 48" Rear Projection...
Cloudy Blue Color Covering Whole Screen
I think its time for sony to face a claas action, they do not supply parts in less than 7 years, and the unit should not have been sold so $high, they should buy them back, that is the best solution
Nov 14, 2008 | Sony KP-65WV600 65" Rear Projection...
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Aug 19, 2008 | Sony KP-46WT500 46" Rear Projection...
Blue ghosting on Panasonic PT-47WX49E
your convergence IVs need to be replaced. Its an easy repair if you can solder. you can get the two ICs you need at the following link. they also provide free installation instructions and free on line tech support while youre doing the repair. You need two ICs they are numbers STK392-110. Let me know if I can be of further assistance. I am one of servicemanuals support techs and board rebuilder.
http://servicemanuals.vstore.ca/
Apr 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Blue and Ywllow ghost
Hi, you need to replace the convergence IC`s and any burnt resistors in front of the IC`s, common with all big screen rear projection tv`s, if you attempt to do this yourself be sure to get original IC`s or your just wasting your time, and it will take you 2 hours easy, any questions email me back, BMW Rider
Dec 24, 2007 | Hitachi 53UDX10B 53" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Jul 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
