Kenmore 24032\24036 Top Load Washer Logo
Posted on Aug 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore series 70 fills with water on rise cycle but stops halfway throught then starts agian and finishes is this normal
Anonymous
Level 3:
President:
  • Master 1,937 Answers
  • Posted on Aug 01, 2010
Anonymous
Master
Level 3:
President:
Answers
1937
Questions
0
Helped
430198
Points
5400
If this has always stopped during the rinse cycle, most likely it's the "cool down" part of the rinse cycle.
See the following Sears site for manuals. Enter your model number and you should be able to download the proper manual for your washer.
http://www.managemylife.com/mmh/owner_manuals/
Kenmore 700 series top loader washer. I put it on the normal cycle, the washer fills and agitates for a few minutes (maybe 5) then drains only to fill back up and finish the cycle. Is this normal?
no
some cycle the agitator during the fill cycle to get better distribution of the clothes as it is filling and then shut of the water and proceed to the wash cycle
have a technician check out the program board
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
2helpful
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
2helpful
6helpful
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
1helpful
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Alexander
vince
