Question about Dometic Refrigerators
Dometic RC3000EGP quit cooling, completely. I believe the refrigerant has leaked. Yellowish residue. I have always vacuumed back, wiped with a damp cloth and totally cleaned the unit after use. I have only used the unit once or twice a year to a fly-in fishing trip. Worked great, electric at home, car plug-in on the road and propane when we arrived in camp. Help!
    Top Expert:
  • Dometic Master
  • 9,445 Answers
Bad cooling unit replace
Posted on Oct 06, 2017
22yooper
  • 828 Answers
SOURCE: Freezer and refrigerator run but is not cold
Remove the back panel at the bottom. The refrigeration system is a sealed system and the smell would not come from it internally. Check and make sure the fan motor is running. If the fan motor (was) shorted out it would account for the reseting of the breaker. After resetting the breaker a number of times would cause the circuit in the fan motor to open allowing the compressor to run. Is the small line coming out of the compressor hot? If so replacing the defective fan motor may correct your problem.
Posted on May 03, 2008
  • 51 Answers
SOURCE: bottom,(refrigerator) isn't cooling at all. the freezer is 20 below zero. what's wrong?
The thermister is located in the fridge. Verify it is clipped to the metal fin Think of this as a knob control move it up and down to control the fridge temp. If this does not help most likely you need a new thermister.
Posted on Sep 07, 2008
  • 68 Answers
SOURCE: Dometic NDR 1292 does not cool
Check to see if your boiler tube is hot. If it is , your cooling unit is shot. Do not plug your circuit board into 110 volt power that will destroy it. To test your heating elements you need to do an ohms reading on the elements. But I can tell you from experience if your boiler tube/ this is the 3-4" diameter sheet metal tube going up the back of the refer/ is hot the cooling unit is no good. If you would like to discuss your diagnostics give me a call.
Jerry
rvtech@myway.com
734 777 6432
www.coachtech.info
Posted on Mar 18, 2009
  • 159 Answers
SOURCE: camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
Posted on May 15, 2009
SOURCE: I have a Kenmore refrigerator not cooling
You will need to replace the heating element, if it looks blacken, then it's not good. When good, it's a clear glass tubing with a coil that heats up. Call Sears for parts.
Posted on Jul 20, 2009
Rm2652 barely is cool to the touch in the freezer and hardly nothing in fridge on electric and does nothing with LP gas...... Why?
If you can hear the coils "circulating" you have a leak in your cooling unit. If you can hear a boiling like sound from the cooling unit it is a tell tail sign that the unit is bad and needs replaced. If you take a look through the access vent on the rear of the fridge you will more then likely see the yellowish residue located around the burner area. This is the common spot for these models to leak. The unit can be easily replaced within just a hour or two with no specialized tools or previous knowledge required. I will attache a copy of our RM2652 installation instructions to view, Please contact Arcticold for your New replacement cooling unit with a Lifetime warranty. 1-888-782-6665 Our Online Store
or Visit ArctiCold Refrigeration We keep it cold
0ad626a4-1449-47d9-8bbf-2fa8d341ab27.jpg f025c046-0397-4b39-bb23-195d5af49be9.jpg 0a8ce3ce-0848-41b0-b50c-20f0b8f695aa.jpg f1777d50-69ba-43e6-9a3c-00e81e4db981.jpg cfd97b8a-7816-472c-98ae-d988ab6f12b2.jpg b8312661-bb6d-437c-b166-2d1d837997fc.jpg
Our install video for that model is
Aug 14, 2014 | Dometic RM2652 Refrigerator
Ammonia lock not cooling
If the RV is level and the cooling unit is warm on the back then you will require a replacement cooling unit. That model is known for leaking just above the burner area. If it has leaked, you will see a yellowish residue around the burner area. The new replacement cooling unit can be purchased online from Arcticold at www.arcticoldStore.com f888c3dc-0ecd-41ec-a155-cbfc5c35b381.jpg ArctiCold Refrigeration We keep it cold 426ce77e-4e27-4bd2-a718-09ab55e70951.jpg
Apr 05, 2014 | Dometic RM2652 Refrigerator
Refrigerator not cooling on electricty or gas
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
Mar 15, 2014 | Dometic DM2652 Americana Fridge...
Dometic DM2652 quit working on elec,tried gas worked for a little than quit,wont cool can hear it running.
If you can hear it running and it sounds like it is gurgling or boiling then it is you cooling unit that has leaked. Your cooling unit is charged with hydrogen and ammonia. When the hydrogen leaks it causes the ammonia to boil more rapidly, hence what you hear. You will require a new cooling unit for your refrigerator. This is something that can be done by anyone in just a few hours with no specialized tools needed. You can give Arcticold a call toll free (1-888-782-6665) or check out our online Store I have also attached a how to video for the installation of a Arcticold New Lifetime Warranty cooling unit. 3a202669-372c-42db-9d46-dcb343b69e0b.jpg
Mar 11, 2014 | Dometic RM2620 Refrigerator
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
Our rv has a dometic rm2600 fridge that smells of ammonia inside and has a little bit of yellow residue in behind service panel. is the fridge wrecked or is it worth repairing. the rv is 27 years old.
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
Apr 27, 2010 | Dometic RM2620 Refrigerator
Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
Jun 13, 2008 | Dometic RM2652 Refrigerator
Fridge not cooling
If you look in the outside compartment do you see a yellowish powder? If you do, or if you smell amonia probably the cooling unit has leaked the coolant. It does not help to add coolant, it will just leak out again quickly. You will need a new fridge or to have the cooling unit replaced. If that is the problem, Dometic has a recall on some models for leaks and will pay for a new cooling unit.
Jun 12, 2008 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
171 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
