Question about Pentair Meteor Above-ground 22" Sand Filter System w/ 1 HP Pump
Pentair Meteor 22 sand filter valve works fine except it will not recirculate. Why??All other functions are fine.
2 Suggested Answers
  • 83 Answers
SOURCE: pentair sand dollar filter is leaking water when
If you have the valve in the Filter position and it is still leaking water out the backwash line, the problem is the Spider gasket inside the valve itself. However, the valve that usually comes with the Sand Dollar filters has the gasket glued to the Diverter, and has to be replaced as one piece, sorry about that!
If you have a manual on the filter, go to the parts page dealing with the valve. If you do not have a manual, the link below will take you to one online:
http://www.pentairpool.com/pdfs/SandDollarOM.pdf
The part that needs replaced in Item #8. What you will do when you get the replacement part is to stop your system, close any valves to stop the flow of water so you do not loose too much. Then you will open up the Air Release Valve and release all the pressure in the filter. Pentair usually recommends that you wait at least 30 minutes after this to make sure there is no presure in the tank. Once this is done, you will remove the screws holding the top part of the valve to the bottom, place the screws is a safe place so yo do not lose them - did that once!- and pull the handle portion up, as a single piece.
Place the top part on a flat surface, and remove the Handle Screw (Item #3) while holding down on the top of the valve. This will help keep the spring in the handle from popping up on you! Slowly raise your hand to allow the spring to expand, no parts will go flying this way! (did that one too!) Then just pull out the old Diverter and replace it with the new one. Reassembly is a bit difficult because of that spring, but once the Handle Screw is in place, it is pretty easy. You DO NOT need to lube the gasket/diverter, so you just line up the diverter sections with those in the bottom of the valve and replace the screws. Just in case, the WASTE position is always OVER the Waste Port on the valve.
Posted on Jul 10, 2009
How does Hayward Sand filter work
Excellent answer Robco, One slight variation of an explanation about "waste"... When in this mode, water never actually enters the filter tank, it goes in the valve from the pump, and out of the valve through the waste port.
Very similar to the "recirculate" mode, it comes from the pool with the help of the pump into the filter valve, and right back out the filter valve, without ever going into the tank, and back to the pool via the return port.
Jun 29, 2014 | Hayward SAND FILTER, PRO SERIES
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
Lost high pressure to spa jets. Pump running , gauge on sand filter shows 30psi ?
backwash and try again if sand is over 3 years old replace but try on recirculate if ok you have a filter problem that I told you about if still no pressure see if impeller is plugged
Apr 22, 2013 | Pentair 1.0 Hp Whisperflo Pump
Was wondering how to change the settings on filter. Its a Hayward Pro Series High Rate Sand Filter and the instruction manual says it have about 5 different ones....i.e. waste, recirculate, but we were...
If you know how to place the valve into the backwash and filter positions you need to use these. The others are important at times but they are not as important. In fact another type of backwash valve has only two positions. This valve is one of the most popular valves for this function so it must not be too bad. I hope this helps.
Aug 20, 2011 | Hayward SAND FILTER, PRO SERIES
Pentair Quad DE system was installed without multiport valve
This is a DE (Diatomaceous earth) IT doesn't have sand and doesn't backwash. You use the bump handle (with pump off and valves closed and vent open and drain dirty water/earth out) Here is a link to the manual for your filter If isn't the exact model they are all on their web site: http://www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Jul 20, 2010 | Hayward EC-40 DE Pool Filter with pump
Recirculating a hayward sand filter for inground poola
no ... waste dumps the water ... recirculate recirculates but does not filter ... filter filters the water ...
Jul 15, 2010 | Hayward SAND FILTER, PRO SERIES
Pentair sm2-pp3 valve, triton II filter. Upon
Lots of sand? You may have a broken lateral in your filter.
To repair, you will have to remove all the sand from the tank to physically inspect.
Might you have changed the sand this year? (top 1/3 needed to be changed every 3 to 5 years normally) If you changed the sand ... did you put water in the filter tank first? If not ... there is a good possibility you broke a lateral (a small pipe with slits in it) when you put the sand into the filter.
It could be that you have too much sand in the filter. Check the owners manual for the clearance - top of sand to top of filter.
Thanks for your interest in FixYa.com
May 14, 2010 | Pool & Spa
I installed a new pentair de filter and new multiport valve. at start up the filter pressure reads 40 psi. after multiple backwashes and rinses the pressure goes down to about 15 psi but slowly climbes...
If the pressure is 15 psi on recirculate, and high on filter, the problem is the filter itself, or the valve plumbing. The DE filters are unusal in the fact that they are plumbed like a sand filter, NOT the cartridge filter. If you could give details as to which filter AND multiport valve you have (look on sticker for model number on valve) it would help to figure out if the problem is in the filter or valve.
Jun 26, 2009 | Pentair "Pentair" In Ground Pool Pump ...
Pentair filter
I am sure that you already have an answer to this, but IF you can not read the valve label sticker, call the Pentair Customer Support 1-800 number. They will send you out a new label, free of charge.
For referrence, the waste position is ALWAYS over the waste port on the valve.
Jun 14, 2009 | Pentair Meteor Above-ground 22" Sand...
Pentair Meteor Above-ground 22" Sand Filter System w/ 1 HP Pump Logo
96 people viewed this question
Top Pentair Garden Experts
Charles T Nevin
Charles T Nevin
David Burbee
David Burbee
David Spradling
David Spradling
Are you a Pentair Garden Expert? Answer questions, earn points and help others
