Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Dryer will stop heating in the middle of the dryng cycle
  • 7,365 Answers
One of 4 things
1.make sure lint trap is clean
2.make sure the dryer duct is clean & also where it exits the house
3.could have a thermostat went bad
4.could have heating element went bad
Posted on Aug 01, 2010
Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 11, 2013 | Bosch Axxis WTA4400 Dryers
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
My dryer stopped heating and spinning in the middle of a cycle of laundry. Is this the element that has gone bad?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 20, 2010 | Estate EED4300TQ Electric Dryer
Dryer is occasionally leaving rusty looking smudge marks on clothing.
don't open door (stop dryer) until cool-down and dryer stops. many times the heating element is still hot and when you stop the dryer in the middle of the cycle, the rear of the dryer where the heating element is, will scorch your clothes.
Nov 29, 2009 | Frigidaire FGQ332ES Gas Dryer
3 yrs old stopped in the middle of a cycle .
need to change thermal fuse,when dryer gets filled with lint they pop,it is a safety device that pops when dryer over heats
Nov 03, 2009 | Maytag Dryers
My dryer just stopped getting hot in the middle of a cycle why
I have had this problem several times. It usually turns out to be the heating element. In some cases it can be a thermostat.
Nov 02, 2009 | Hotpoint TDC32 Electric Dryer
Stopped working all together
replace controls
Feb 01, 2009 | Dryers
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
204 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
