I need the HON-1 scanner connector for the Snap-on diagnostic scanner.
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the problem.
Thanks
Posted on Aug 08, 2010
What do these Transformers go to?
try google (1. Ktec KA12D120030033U 2. HON-KWANG D12-10-1000 part no: SAM01T) maybe one at a time
Dec 21, 2017 | Computers & Internet
95 buick lesabre check engine light goes on every time i hit passing gear or climb a hill. when i restart car it is off again.
Sorry to say, that is one of those GM cars that is difficult to retrieve trouble codes without special scanners. It was on some '94 and '95 GM luxury or upscale models (your LeSabre was one), where they put in the new diagnostic connector that became standard on all cars built after 1996- and called OBD-2 (for On Board Diagnostics, second generation). The problem is, your '95 model is typical of all early '90's cars and trucks equipped with the OBD-1 system. It only has 2 digit trouble codes, and there are not a lot of them, only about 2 dozen in total. The whole system is OBD-1, but the diagnostic connector is configured like an OBD-2 connector.
Some shops might have the scanners necessary to work on your car, some with high end scanners. Of course, GM dealerships would have the right testers, but they are outrageous in prices.
I would try to find someone who could get the codes for you. What you describe sounds to me a lot like a bad Mass Airflow Sensor, or MAF sensor. That is just a guess, though, and why I recommended you try to see if there are trouble codes. There should be at least one.
Nov 25, 2016 | 1995 Buick LeSabre
I have no fuses blown under hood or in fuse panel on dash side code scanner will not power up or work at all
With key in on do you have all dash warning lamps on, and the check engine light is on? If that's all okay, and still nothing on the scanner, it is possible the wiring to the diagnostic port got messed up. You would need a wiring diagram to really see the wires involved. By the way what year is your vehicle? All after 1996 have the same obd-2 connector. There were some variations leading up to the '96 model year. I recall some dismayed GM owners of '94 & '95 models, especially luxury class models, that had obd-2 connectors and obd-1 diagnostics, same as all the early '90's GM vehicles. Back then, GM and Chrysler were always a step ahead of Ford, beginning in the early '80's. ! enough nostalgia, did u figure it out with your scanner?
Nov 10, 2015 | Cars & Trucks
What diagnostic socket have I got, after diagnostic tool
Question doesn't make sense. Explain more fully. What diagnostic tool do you have? I've never heard of a diagnostic socket. Do you mean the OBD connector? All models from 1996 on use a universal connector, called an OBD-II connector. On Board Diagnostics- since 1996, all vehicles sold in the USA are required to have the same connector. Fits any OBD scanner or code reader.
Sep 12, 2015 | Cars & Trucks
Where is the diagnostic port in my 1995 jeep cherokee 2 door 6cyl 4.0l
For 1995 Jeep Cherokee 4WD 4.0L MFI 6cyl the OBD Diagnostic Link Connector is located: Under hood, driver side, front side of shock tower, mounted on wheelwell
Hope helps.
May 01, 2011 | 1995 Jeep Cherokee
Error code 52.0
A laser/scanner error has occurred
Recommended action:
1. From the DIAGNOSTICS menu, run the
laser/scanner motor component test.
Verify that you can hear the motor
rotate.
2. If you cannot hear the motor rotate,
verify that connector J1702 and J1505
are fully seated on the DC controller
PCA (ECU).
3. Verify that the connector J12 on the
laser/scanner assembly is securely
attached.
4. If the error persists, replace the laser/
scanner assembly
Jan 18, 2011 | HP LaserJet P3005n Printer
Computers & Internet Logo
14 people viewed this question
Alun Cox
David Payne
David Payne
