Question about Boating
I have a 1997 merc 150EFI saltwater. At any point in time regardless of rpm or temp the motor will stall. The motor will start right back up and you are on your way,it may run for an hour or 30 seconds before stalling again. I have changed the cdi,all 6 coils and the ecu. I have tested the trigger and the stator charges 13-15 volts depending on rpms. I changed all the fuel filters and checked the fuel lines for debris. i even ran it on an auxillary fuel tank just to take the boats tank out of the mix. I also checked all the plugs and harnesses for corrosion.
  • Dan Aug 01, 2010
    thanks i will try that
    Top Expert:
  • 81,400 Answers
This engine has self test abilities,so when a problem occurs it can set a fault code in the EFI control modules memory, I suggest u have the dealer use a Merc scanner and see what codes are in memory, just guessing is costly and labor intensive,i believe you may have a problem related to the control module or the ignition system, each will set a fault code
Posted on Aug 01, 2010
Motor shuts off when started up,shuts off when driving.
hot engine or cold, or both? 180F+ is hot.
Shuts off, idling or on the fly, say at 30mph right foot down it dies?
just clue here...
engine stalls. is complex. but in the macro its below, using tools finds the reason,, but you never said did it restart easy./??????
1: lost of engine compression hot engine, (or overheated)
2: lost 12vdc electric power at stall (caused it) dash goes dead. ?
3: lost spark, test spark at the failure point. if dead trouble shoot speak.
4 bad fueling, too lean (say the fuel pump dies) or too rich.
too rich causes wet spark plug tips. (lots of causes )
5: stalls due to idle RPM too low, below 800 is too low.
too low idle rpm is caused by many things, but top 2 are.
A: EGR stuck wide open, clean it, as the books shows at 60k miles
B: ISC stuck closed. (same deal clean it)
now repost and say when it stalled,
at a read light or flying up a hill wot, wot= wide open throttle.
and when it dies, is the restart easy or hard.
Dec 05, 2013 | 1997 Jeep Grand Cherokee
I have new 40hp mecury lightining my problem is when i take off feels slugish and does not take off like two stroke should. i was told its the set size origional at 0.80 should be at 0.85 is this the...
I'm assuming that you mispelled and set should be jet. I'm also assuming that you're at a higher altitude. That could mean changing jet would improve performance. Changing your original propeller which was designed for sea level could also help. I know that my 115 horse Merc could only get up to 4200 rpm with the factory prop that was 17 degree prop. I changed to a 15 degree and got to 5200 rpm and a 13 degree got me to 6000 rpm. It's a little expensive but to get to optimal performance for your motor you'll probably need to change jets and prop.
Nov 12, 2009 | Light Outboard Motor Boat Bass Fishing...
94 Bravada that stumbles and stalls.. won't start when warm..
Try checking the exhaust flow when someone else is pushing down on the gas petal.The farther the petal gos down,the more exhaust should be coming out. I replaced my catalitic convertor at 44000 miles, it was clogged. I had them install a high flow type.
Sep 03, 2009 | 1994 Oldsmobile Bravada
2002 Merc. outboard overheating
it sounds like your lower unit pump is going out
hook it to a fresh water hose and run the engine and see if more water comes out of the exaust if it is more then i would replace the lower unit pump check and see if the screens on the lower unit are plug up with seaweed and clean them that would restric the flow of water
Aug 30, 2009 | Sport & Outdoor - Others
97 bonneville intermitant stalling
leake intake manafold or bad vac line... try warm soapy water on running motor out of a spray bottle to find leak... the reason the censor seemed to hel is that the take time to set them selfs... after set back to square 1 leak in the air side of motor... typical in your car...
Jul 08, 2009 | 1997 Pontiac Bonneville
1997 Jeep Grand Cherokee. Stalls out,engine quits running
since its a 1997 your jeep has EFI, electronic fuel injection. The most probable reason for your troubles would be the injectors or a problem with the computer controling them, not allowing enough gas to be pushed into the cylinder causing stalling or lack of power, also too much gas iin the cylinder can lead to back firing and stalling. This would also explain the reason it takes so long to start back up some times, all the excess gas in the cylinder is flooding the motor and u have to wait till the gas disipates till the engine will turn over.
Mar 21, 2009 | 1997 Jeep Grand Cherokee
1983 volks rabbit 1.6 L starts o.k. but stalls when warm low rpm
This is caused by a faulty temp sensor, look at the top of the engine coming out of the head right near the distributor there is a coolant housing with a coolant line which should have one maybe two sensors one will be black (square with 2 to 4 wires) the other one will be blue. If yours only has one connector then disconnect it, start engine...the engine may idle higher than normal drive it till it warms up or to the point where it would normally stall, if it doesn't stall then replace the sensor and problem solved.
If you have two sensors, black one and blue one, its been awhile for me but disconnect one or the other, one of them is your temp gauge sending unit can't remember if its the blk one or blue one. But try that.
Mar 18, 2009 | Volkswagen Rabbit Cars & Trucks
Stalling when engine temp reaches 160 degrees
Here are my theories
Idle Air Control valve (IAC) - allows a small amount of air to pass though throttle body at idle since the butterfly in the throttle body is closed at this time - if this doesn't open the vehicle will stall
Air Intake Temp Sensor - Helps correct air fuel ratio by measuring the temp of the air coming through the intake
Oxygen Sensor - Largest determinate of air/fuel ratio after the vehicle almost reaches operating temp which is approx 160 degrees
Coolant temp sensor - Largest determinate of the air/fuel ratio from cold up to the point when the oxygen sensor takes over
EGR Valve - 5.2 Liters are known for these failing, they redirect a small amount of exhaust gases back into the intake manifold for re-burning (emissions thing). Sometimes they get stuck closed and allow for too much exhaust gas back into the manifold. But usually this would cause very poor performance as well as shuddering and stalling
Use what you know about your condition and what these common fail items are and see if any of them sound like the problem
May 21, 2008 | 1994 Jeep Grand Cherokee
Boating Logo
20 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
