Question about Singer Sewing Machines
Need to find out how to thread my singer fashion mate model # 239 sewing machine
  • Singer Master
  • 7,365 Answers
On website called --diplodocs.com
on first page go to left hand side of page to the alphebet letters find S find the word singer click on it,,it will take you to the next page
toward the middle there a box that says most common searches
find your model number -it's in there & click on the model number & it will take you to the download page you have to answer 3 questions about your sewing machine to get the download but there easy questions & the download is free it's a pdf file
Posted on Aug 05, 2010
I'm getting an E2 error message on a Singer 8768 Heritage model.. Re-doing bobbin and bobbin placement but still getting the message.
This answer on Pinterest:
How to Fix Code E2 on Singer Fashion Mate Sewing Machine 7256 eHow
In case you are unable to view--here is the text:
The Singer 7256 Fashion Mate sewing machine has a top drop-in thread bobbin and an automatic needle threader. The digital display on the side of the machine is used to select different stitch settings on the machine. When the display reads error code E2, it means that there is a bobbing threading error, which may be caused by the thread looping or bunching under the fabric as you sew.
Things You'll Need
  • Pen
  • Screwdriver
  • Push the bobbin-winding spindle of the sewing machine back to the left.
  • Turn the hand-wheel toward you, hold the needle thread (thread on the sewing machine needle) and tug it lightly as the needle goes down and then raises up. A small loop will raise up through the needle plate on the sewing machine. Use the tip of a pen to lift the loop up through to the back of the machine.
  • Check the position of the needle. It should be seated in the sewing machine with the flat side facing the back of the machine. If it is not, remove the needle and reinsert it so that it is facing the correct way.
  • Remove the bobbin case. Use a screwdriver to turn the screw on the side of the bobbin until the loops of thread pull taught and are removed.
  • Remove any loose fibers or threads that may be stuck in the tension disks.
  • Reset the upper tension disks. Raise the presser foot lever up. Put the tension setting of the sewing machine on setting "4." Hold onto the spool of thread in your right hand and with your left, route the thread down through the tension channel, around the bottom of the disk and up the other side. When done correctly, the thread will click into place and slip in between the tension disks.
  • Set the thread bobbin in the bobbin case, with the thread passing over the top of the bobbin and then down to the right. Route the thread through the notch located at the left of the bobbin case and pull it through. Move the thread over the top of the throat plate and over to the back of the machine.
Tips & Warnings
  • Using incorrect bobbins may cause error E2 to occur. Not all plastic bobbins are the same size, so check the model number of the bobbin to ensure that you are using the correct one with your sewing machine.
  • Never turn the hand-wheel on the sewing machine away from you, as it will change the timing on the sewing machine.
Singer 8768 HERITAGE Instruction Manual Page 58
Dec 05, 2016 | Singer Heritage 8768 Electronic Sewing...
Singer fashion mate 237
here is a link for part for the machine
Singer 237 Parts
May 02, 2014 | Sewing Machines
Singer fashion mate parts charts for singer sewing machine
Just quote you model number with the Dealer...
Mar 22, 2014 | Singer Sewing Machines
Fashion mate 252: the thread keeps coming out of the needle as I sew. what am I doing wrong?
You may have the machine threaded wrong that is the only possible thing wrong or you may be using inferior thread if it happens when sewing
Oct 30, 2013 | Singer Sewing Machines
Diagram on how to thread a #239 singer sewing machine
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 239 ) & click search
or try sewusa.com they have some threading diagrams
May 01, 2012 | Singer Sewing Machines
I have a singer fashion mode model 239 but no manual I can sew but only plain things where can I download a free manual for this machine?
hi,Mary
They have a free instruction manual download on singer website
On the homepage at the bottom look for instruction manual & click on it
It will take you to a page where there's a box put in the model number 239
Then click search
The second one is a free download
Sep 19, 2011 | Singer Sewing Machines
My singer model 237 makes a stitch that doesn't look right. The bottom thread is just goes through the top thread loops under the material
Hi, if stitches are off, there is a problem with balance between the upper and lower stitch adjustments. You have to tweak these. Also, make sure there is no lint in the bobbin case area or under the feeddogs. Here is an excellent blog for 237 Fashion Mate owners. You are lucky to have one of these from the 1960's. http://blog.sew-classic.com/2010/02/02/singer-237-fashion-mate-sewing-machine-reveiw.aspx
Happy Sewing!
Jul 17, 2011 | Singer Sewing Machines
Was given an old model Singer 237 Fashion Mate with no manual. cannot get the bobbin to thread properly.
We'll here is a picture of what I need help on I need to know how to put the needle back along with the needle clamp screw
Jul 09, 2009 | Singer Sewing Machines
Sewing Machines Logo
199 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
