Question about LG DLE2514 Electric Dryer
I have a brand new LG gas steam dryer. The flow sensor shows 4 bars which the manual says means I need to clean the ducts and remove a blockage. What ducts? Under the lint filter? Clean with what tool? Is the sensor just really sensitive?
  • 93 Answers
SOURCE: LG DRYER 5955 - No heat; 4 bars in test phase; NO blockage!
some dryers have what is called a thermo fuse if it overheats due to bad venting the thermofuse opens and need to be replace it whit about 1:lonk mounted on the back of the dryer cost aprox 6.00 thanks from gilles
Posted on Mar 15, 2009
  • 686 Answers
SOURCE: LG Tromm Dryer keeps blowing breaker
yes breakers go bad change it and repost if not solved
Posted on Apr 06, 2009
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Posted on Jun 16, 2009
SOURCE: LG DRYER 5955 W FRONT LOAD
I had the same prob. and got this from LG:
Dear James,
Thank you for contacting LG. We are delighted to hear from you as our Valued Customer. I sincerely apologize for the delay and any inconvenience you are going through with your unit.
I will be more than glad to assist you.
When the venting is just installed, in order to see the correct result in the vent testing option of your unit, is necessary to wait for 2-3 full cycles.
If after this period of time, the correct results do not appear, please contact us back via e-mail or call our Customer Service Department
If you have other questions or concerns, please do not hesitate to contact us again either via email, or by calling our customer service division at 800-243-0000 at your convenience.
Emely M.
E-mail Administrator
Customer Interactive Center
LGEAI
Posted on Nov 01, 2009
omaharox
  • 166 Answers
SOURCE: the check filter light keeps coming ob to my lg
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Posted on Jan 20, 2010
Drum turns..no heat
I would check inside and see the blower itself it may have lint or debris obstructing it, see if u can turn it by hand another thing to check is for full 220 at the outlet and terminal cuz if u only get 110 u will be able to run motor but have no heat
Mar 29, 2015 | LG DLE5001W Dryer
Keep getting warning "check exhaust" on a new gas dryer. All exhaust is clear. What's going on?
The CHECK VENT duct blockage sensing system detects and alerts you to blockages in the duct work that reduce exhaust flow from the dryer. This light does not indicate any problems with your dryer. If this light blinks, it indicates that your home's exhaust system/duct work has a serious restriction
Every time the dryer is turned on, the CHECK FILTER LIGHT WILL BLINK, as a reminder to make sure the filter is clean. Always make sure the lint filter is clean before starting a new load; a clogged lint filter will increase drying times.
The Kenmore Elite dryer has a sensor that detects poor exhaust venting, and when it does, a light flashes on the control panel. This warning light does not include a mechanism to stop gas flow, but if it is allowed to flash for an extended period, poor venting may cause the dryer to overheat. As a result, a fuse might blow and disable the gas valve or ignitor. You can prevent this by diagnosing the reason for the flashing indicator light as soon as possible.
In many cases, LINT has built up somewhere in the exhaust pipes.
Check under the lint filter. Pull it out,look inside the slot it fits in, and clear all lint from this area.
Is it possible you have used the WRONG VENT MATERIAL?
Check your vent to make sure it is 4 inch rigid or semi-rigid metal ducting. If your venting is plastic or flexible foil, replace it before using the dryer.
Check your vent hood outside. You may have a restricted or damaged vent hood. It must be clean and free of lint buildup. Check the damper and make sure it opens fully and easily and is free of lint.
I know you said you have no elbows, but I have posted the pipe run lengths with and without elbows. Keep in mind this is with 4 inch rigid or semi rigid metal ducting.
Measure the length of your exhaust system and count the elbows. Use the chart below to see if your duct is too long. If it is too long, have the duct routed to another location that is within the venting guidelines.
0~90 degree elbows=65 ft of 4 inch rigid metal duct.
1~90 degree elbow=55 ft of 4 inch rigid metal duct.
2~90 degree elbows=47 ft """"""""
3~90 degree elbows=36 ft """"""""
4~90 degree elbows=28 ft """"""""
You should always use duct tape or metal tape on all joints, NEVER USE SCREWS, as screws capture lint inside the pipe.
One more note. Lots of people overlook the fact that fabric softeners can build up on the lint filter over time. This buildup can restrict the airflow through the filter reducing dryer efficiency and lengthening drying times. After removing lint, if the filter looks dark or dirty when held up to the light, follow these steps to clean:
Use hot soapy water and a stiff brush to clean
the filter.
Make sure the filter is completely dry before
reinstalling it and using the dryer.
NEVER operate the dryer with a wet lint filter.
Oct 29, 2014 | Kenmore Dryers
My dryer says to check the lint trap
A sensor is saying ". . .airflow is blocked. . " Blockage could be the air filter or trap or ducts within the dryer or the 4" flex duct attached to the back. First, remove the 4" duct and see if there is good air flow with dryer running. If so, ream the duct all the way to the outside. If not, disassemble dryer to get to internal rigid ducting and blower. Also, make sure the blower wheel is not broken and can rotate freely.
Oct 17, 2014 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
LG Gas Dryer (Model # DLG5988W) is not heating, the gas is not turning on. When the dryer is turned on the ''Check Filter'' light comes on and when switching to a drying cycle the ?Cool? light is always...
The dryer has a resettable SAFETY thermostat located on the flame tube inside the dryer. LG recommends replacing the Safety and High limit thermostats if the Safety thermostat is tripped. The dryer Glow bar igniter could be bad as well as the gas valve or Main computer. Time to have the dryer serviced by a qualified LG tech. LG has factory service tech in most large cities. Give them a call at 1 800 243-0000.
Hope this helps.
Mike
Oct 31, 2017 | LG Dryers
Dryer flow sensor shows 4 bars
lint trap holder has got some lint overflow caught down inside it ,past lint screen , I use a piece of small pool pump hose taped to the end of a normal vacuum to suck it out
May 08, 2009 | LG DLE5955 Dryer
Mar 15, 2009 | Dryers
It takes three cycles to dry clothes, andthere is heat?
The most likely cause is poor airflow. This may be due to a clogged lint screen (should be cleaned after each load) or a clogged vent. Run the dryer empty and feel the airflow from the vent outlet (where the vent exits the house). If there isn't a good strong flow of air, remove the duct where it attaches to the dryer and check for flow right at the dryer. If there still isn't good flow you may have a bad blower, but chances are the duct is clogged with lint. If it's the white plastic flexible duct or the corrugated metal kind you should replace it with solid 4-inch vent pipe. This will give the best airflow and the smooth walls won't promote lint buildup.
Jan 26, 2009 | Kenmore 22422 Top Load Washer
LG DLE2514 Electric Dryer Logo
176 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
