Question about Pioneer DEH-P5000UB Car CD/ MP3 Player
I have the pioneer deh-p5000ub.. how do I set the radoi station on it, so that I can go to my fav. radoi channels? for each group/list setting it has 3 setting group. that I can put 5 or 6 radio station on each group/settings list. I can put a channle on each one of the groups/ list settings. to change from setting / group loist 1- then 2 - then -3. one radoi channle on each . but i should be able to put on it 6 dif. radoi channels on each one of the 3 setting/group list. help me please
How to reset my DEH-P5000UB, because my display turned off, weird
Re:"everyother light turns on the faceplate but the display is off"
That means that the unit is either faulty, or one of the two powered lines required had not been connected.
The unit is reset by simply disconnecting the connector at the back.
This will not help in fixing the problem.
Ensure that unit is wired properly. Use a voltmeter to test wiring.
Here installation manual with proper wiring.
Here also the owner manual.
May 26, 2010 | Pioneer DEH-P5000UB Car CD/ MP3 Player
I cant set the clock on my pioneer p5000ub radio
Here is the link to your manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/212724165DEHP4700MPOperationManual.pdf
Set the clock:
press function to select clock, press left or right to select the part of the clock display you want to set, press up down to set the clock.
Cheers!
Dec 28, 2009 | Pioneer DEH-P4700MP CD Player
P5000UB wiring diagram
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 25, 2009 | Pioneer DEH-P5000UB Car CD/ MP3 Player
Pioneer DEH P4100
  1. well to set the clock you need to first hold the source button to turn it off to where the clock is just on. then press and hold the clock button until it beeps then use the arrows to set the clock..........
  2. and to set the stations you need to tune in your fav station and then press and hold the number you want to place that station. you can also do best station memory if you are in an unfamiliar area or if you just want to fast tune all the local stations that come in the best it will randomly preset the stations by pressing and holding till it beeps on the program bottom. then the screen will run BSM until it finds and places the stations. hope this helps!
Feb 16, 2009 | Pioneer DEH-P4100
Setting radio station to a channel on a Pioneer DEH-525R cd player
Scroll to the station then press and hold the preset button you want it to goto.
May 23, 2008 | Pioneer DEH-P2000 CD Player
Setting radio stations on pioneer DEH-525R CD player
Scroll to the station then press and hold the preset button.
The solution for setting the radio station on a Pioneer DEH P2000, is to tune the station you want programmed and hold down the desided channel number until the program number appears on the display.
BC
Setting up fav stations
seek to the station you want and hold down the preset button you want that specific station set to.
for ex: seek to 101.3fm and hold down the number 1 preset button for about 5 sec.
May 11, 2008 | Pioneer DEH-445
Pioneer DEH-P5000UB Car CD/ MP3 Player Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
