Question about Bionaire BPF1140-U Oscillating Power Fan
The plastic bracket holding the fan into the base mount broke. Would you know where I could get a replacement part?
My wife hit a limb and broke the passenger side mirror so that it is hanging loosely and will not operate properly. How do I fix it?
check the mounting bracket if its broken you'll have to replace that , also, check the mount on the door itself, they get bent and with a little TLC can usually be bent back in place,, remove the inside trim piece to the mirror mount inside the door , from there you can see the mounting bolts that hold the mirror in place, if the actual plastic section of the mirror got broke, there is no real fix for that , I suggest getting a replacement at a local junk yard,
Jul 22, 2011 | Buick Park Avenue Cars & Trucks
Moen eva tissue holder broke, how do we fix it?
Specifications and Installation Instructions:
http://www.moen.com/shared/pdf/yb2808sp.pdf
Identify the parts needed and the part number from above.
To order replacement parts:
http://www.moen.com/replacement-parts/search?context=modelNumber&value=YB2808CH
If your tissue holder has simply come loose it is likely the the wall mount will need to be replaced or at the very least tightened. You will need to remove the tissue holder from the mounting bracket. Insert a small flat screw driver in the square hold at the underside of the base of the mounting post to release the locking tab. Try to tighten the screw holding the mounting braket; if it will not tighten you may need to replace the wall anchor. Once the wall anchor is replaced you can reinstall.
Apr 02, 2011 | Home
Alternator base , mount or bracket broke . Is it
Should be just a bracket, contact a salvage yard for info and best price. Some times even Ebay has these kind of parts...
Oct 01, 2010 | 2001 Chrysler Town & Country
Missing bracket to mount fan to electric outlet box
They sell universal fan hanger brackets at home depot for a few dollars. they will be in the same section as the lamp parts.
Sep 06, 2009 | Hampton Bay HL52QV-P-3LC14 Brass Landmark...
I have a Kenroy International ceiling fan
Fixya does not sell replacement brackets.
Aug 07, 2017 | Dryers
The fan motor/bracket that attaches to the mounting bracket is broke and i would like to know if this can be replaced
Call Hunter (800)893-9330 for a new bracket. They should replace the damaged bracket for free or a nominal fee. They have a potential liability if the bracket is defective. If you broke it, that's another story.
Jul 29, 2009 | Hunter 20347 Ceiling Fan
I need a celing mounting bracket for 52in 5 blade encon ceiling fan. where can i get one the model # is 94b03-0395
I just uninstalled my 29 year old Encon flush mount fan light. The number on the base is E101004. It was a lighted base. The mount bracket is built into the base. It is the 4 prong and hook style the allows the motor to hang suspended while wiring and then swings up. There is a glass ring that is sandwiched between the base plate and decorative bottom.
It's the only usable part besides the 4 glass light covers. You can save this from the land fill if you haven't purchased a replacement fan.
May 08, 2009 | Encon Industries 78716 Contempra Ceiling...
Heat sink fan P4VMM2 v 3.2A
Which one of these CPU's are you using?
Jun 17, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Remove base from TV
Remove 4 screws holding the vertical metal bracket in place. These are located just above the bottom of the rear centre of the TV. The bracket will then slide out.
You might find it easier to remove the footplate first. Simply remove all screws from the bottom of the base. The metal plate and the plastic shield will then detach.
May 27, 2008 | Televison & Video
Bionaire BPF1140-U Oscillating Power Fan Logo
22 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
